Datasheet Texas Instruments TS3L301DGGG4 — Даташит
Серия | TS3L301 |
Модель | TS3L301DGGG4 |
Гигабитный сетевой коммутатор 16–8 бит SPDT с низким и равномерным сопротивлением в открытом состоянии 48-TSSOP от -40 до 85
Pin | 48 |
Package Type | DGG |
Industry STD Term | TSSOP |
JEDEC Code | R-PDSO-G |
Package QTY | 40 |
Carrier | TUBE |
Маркировка | TS3L301 |
Width (мм) | 6.1 |
Length (мм) | 12.5 |
Thickness (мм) | 1.15 |
Pitch (мм) | .5 |
Max Height (мм) | 1.2 |
Mechanical Data | Скачать |
Additional Features | Powered off protection |
Полоса частот | 900 МГц |
Bandwidth(Max) | 900 МГц |
Configuration | 2:1 SPDT |
Crosstalk | -90 дБ |
ESD Charged Device Model | 1 kV |
ICC(Max) | 600 uA |
ICC(Typ) | 250 uA |
Input/Ouput Voltage(Max) | 5 В |
Input/Output Continuous Current(Max) | 128 мА |
Input/Output OFF-state Capacitance(Typ) | 10 пФ |
Input/Output ON-state Capacitance(Typ) | 3.5 пФ |
Количество каналов | 8 |
OFF-state leakage current(Max) | 1 мкА |
Package Group | TSSOP |
Package Size: mm2:W x L | 48TSSOP: 101 mm2: 8.1 x 12.5(TSSOP) PKG |
Время задержки распространения | 0.25 нс |
Protocols | 10 BASE-T,100 BASE-T,1000 BASE-T,LVDS |
RON Flatness(Typ) | 0.7 Ohms |
Ron Channel Match(Max) | 1.2 Ω |
Ron(Max) | 8 Ohms |
Ron(Typ) | 4 Ohms |
VCC(Max) | 3.6 В |
VCC(Min) | 3 В |
VIH(Min) | 2 В |
VIL(Max) | 0.8 В |
- Preventing Excess Power Consumption on Analog SwitchesPDF, 238 Кб, Файл опубликован: 3 июл 2008
Analog switches are extensively used for switching audio signals in battery-powered applications, such as mobile phones. In any cases, the switch is powered directly from the battery, but it receives control signals from a lower voltage processor GPIO. For most analog switches, this application condition leads to an excess supply current draw that catches system designers by surprise. This applica
Серия: TS3L301 (6)
- TS3L301DGG TS3L301DGGG4 TS3L301DGGR TS3L301DGGRE4 TS3L301DGGRG4 TS3L301DGVR
- Semiconductors > Switches and Multiplexers > Protocol Specific Switches/Muxes
