Datasheet Texas Instruments TS5A3357DCURG4 — Даташит
Серия | TS5A3357 |
Модель | TS5A3357DCURG4 |
Одиночный аналоговый переключатель SP3T, 5 Ом, 5 В/3,3 В, аналоговый мультиплексор/демультиплексор 3:1, 8-VSSOP от -40 до 85
Pin | 8 |
Package Type | DCU |
Industry STD Term | VSSOP |
JEDEC Code | R-PDSO-G |
Package QTY | 3000 |
Carrier | LARGE T&R |
Маркировка | JA9R |
Width (мм) | 2 |
Length (мм) | 2.3 |
Thickness (мм) | .85 |
Pitch (мм) | .5 |
Max Height (мм) | .9 |
Mechanical Data | Скачать |
Additional Features | Powered off protection,Break-before-make |
Полоса частот | 334 МГц |
Bandwidth(Max) | 334 МГц |
Configuration | 3:1 |
ESD Charged Device Model | 1 kV |
ESD HBM | 2 kV |
Input/Ouput Voltage(Max) | 5.5 В |
Input/Output Continuous Current(Max) | 100 мА |
Input/Output OFF-state Capacitance(Typ) | 4.5 пФ |
Input/Output ON-state Capacitance(Typ) | 17 пФ |
Количество каналов | 1 |
OFF-state leakage current(Max) | 1 мкА |
ON-state leakage current(Max) | 1 мкА |
Package Group | VSSOP |
Package Size: mm2:W x L | 8VSSOP: 6 mm2: 3.1 x 2(VSSOP) PKG |
Rating | Catalog |
Ron(Max) | 50 Ohms |
Ron(Typ) | 5 Ohms |
Supply Current(Max) | 10 uA |
Supply Range | 5.5 Max |
VIH(Min) | vcc*.7 В |
VIL(Max) | vcc*.3 В |
Vdd(Max) | 5.5 В |
Vdd(Min) | 1.65 В |
Vss(Max) | N/A В |
Vss(Min) | N/A В |
- Preventing Excess Power Consumption on Analog SwitchesPDF, 238 Кб, Файл опубликован: 3 июл 2008
Analog switches are extensively used for switching audio signals in battery-powered applications, such as mobile phones. In any cases, the switch is powered directly from the battery, but it receives control signals from a lower voltage processor GPIO. For most analog switches, this application condition leads to an excess supply current draw that catches system designers by surprise. This applica
Серия: TS5A3357 (4)
- TS5A3357DCUR TS5A3357DCURE4 TS5A3357DCURG4 TS5A3357DCUT
- Semiconductors > Switches and Multiplexers > Analog Switches/Muxes
