Datasheet Texas Instruments TMS320LF2407PGEA — Даташит
СерияTMS320LF2407
МодельTMS320LF2407PGEA
16-битный DSP с фиксированной запятой и Flash 144-LQFP от -40 до 85
TMS320LF2407, TMS320LF2406, TMS320LF2402 DSP Controllers (Rev. I)
PDF, 1.5 Мб, Версия: I, Файл опубликован: 11 сен 2003
Pin144
Package TypePGE
Industry STD TermLQFP
JEDEC CodeS-PQFP-G
Width (мм)20
Length (мм)20
Thickness (мм)1.4
Pitch (мм).5
Max Height (мм)1.6
RoHSНе совместим
  • Evaluation Modules & Boards: TMDSEZD2407
    TMS320LF2407A eZdsp Starter Kit (DSK)
  • DSP Solution for AC Induction Motor
    PDF, 183 Кб, Файл опубликован: 1 янв 1996
    The Motor Control industry is a strong aggressive sector. Each industry to remain competitive, must reduce costs but also has to answer to power consumption reduction and EMI radiation reduction issues imposed by governments and power plant lobbies. The results of these constraining factors are the need of enhanced algorithms. DSP technology allows to achieve both, a high level of performance as
  • Implementation of a Speed Controlled Brushless DC Drive Using TMS320F240
    PDF, 157 Кб, Файл опубликован: 1 янв 1997
    The DSP Controller TMS320F240 from Texas Instruments is suitable for a wide range of motor drives. TMS320F240 provides a single chip solution by integrating on-chip not only a high computational power but, also, all the peripherals necessary for electric motor control. The main benefits are increased system reliability and cost reduction of the overall system. The present application note describ
Серия: TMS320LF2407 (3)
  • Semiconductors > Microcontrollers (MCU) > Performance MCUs > Real-time Control > C24x 16-bit Series
На английском языке: Datasheet Texas Instruments TMS320LF2407PGEA
