Оптопары и оптореле Megawin
Datasheet Texas Instruments TPA2001D2PWPR — Даташит
СерияTPA2001D2
МодельTPA2001D2PWPR
Стереоусилитель звука класса D, 1 Вт, 24-HTSSOP от -40 до 85
1-W Filterless Stereo Class-D Audio Power Amplifier datasheet
PDF, 370 Кб, Версия: A, Файл опубликован: 25 апр 2000
Pin24
Package TypePWP
Industry STD TermHTSSOP
Package QTY2000
МаркировкаTPA2001D2
Width (мм)4.4
Length (мм)7.8
Thickness (мм)1
Max Height (мм)1.2
  • Evaluation Modules & Boards: TPA2001D2EVM
    TPA2001D2 Evaluation Module (EVM)
  • Layout Guidelines For TPA300x Series Parts
    PDF, 647 Кб, Файл опубликован: 15 июл 2003
    This article provides a well-reinforced procedure for the PCB layout task as it pertains to the TPA300x series of class D amplifiers. This information can also be used in the layout of the TPA200x series, or any other class D audio amplifier.This task needs a logical sequence. If we simply jump into the layout task, without understanding how the circuits work, we risk not having an optimal end
  • Measuring Class-D Amplifiers for Audio Speaker Overstress Testing
    PDF, 175 Кб, Файл опубликован: 28 окт 2005
    This application report presents the results of an experiment conducted to demonstrate how to address the two most common concerns regarding speaker damage using Class-D amplifiers.
Серия: TPA2001D2 (2)
  • Semiconductors > Audio > Low-Power Audio Amplifiers (<10W) > Speaker Amplifier Class AB/Class D
На английском языке: Datasheet Texas Instruments TPA2001D2PWPR
