Datasheet Texas Instruments V62/12622-01XE — Даташит
СерияTMS570LS20206-EP
МодельV62/12622-01XE
Усовершенствованный продукт: 16- и 32-битный флэш-микроконтроллер RISC 144-LQFP от -55 до 125
TMS570LS20206-EP, TMS570LS20216-EP 16/32-Bit RISC Flash Microcontroller datasheet
PDF, 967 Кб, Версия: A, Файл опубликован: 2 авг 2012
Pin144144
Package TypePGEPGE
Industry STD TermLQFPLQFP
JEDEC CodeS-PQFP-GS-PQFP-G
Package QTY6060
CarrierTUBETUBE
МаркировкаS20206ASPGEMEPTMS570LS
Width (мм)2020
Length (мм)2020
Thickness (мм)1.41.4
Pitch (мм).5.5
Max Height (мм)1.61.6
  • Triangle/Trapezoid Wave Generation Using PWM With Hercules N2HET
    PDF, 476 Кб, Файл опубликован: 1 май 2015
    This application report illustrates how to generate various forms of triangle and trapezoid waves using the versatile programmable high-end timer (N2HET). The examples can be run in either the Hercules hardware development kit (HDK) or the Launchpadв„ў development kit. The application report shows the N2HET program examples, the steps to setting up the N2HET registers as well as basic system s
  • Sine Wave Generation Using PWM With Hercules N2HET and HTU
    PDF, 371 Кб, Файл опубликован: 12 май 2015
    This application report illustrates how to generate sine waves using the versatile programmable high-end timer (N2HET) and its companion data transfer unit (HTU). The code example can be run in either the Hercules hardware development kit (HDK) or the Launchpadв„ў development kit. The application report shows the N2HET program examples, the steps to setting up the N2HET and HTU registers as we
  • Semiconductors > Space & High Reliability > Microcontroller > Performance MCU > Safety Products
V62/1262201XE, V62/12622 01XE
На английском языке: Datasheet Texas Instruments V62/12622-01XE
Публикации по теме
