Datasheet Texas Instruments OPA4234U/2K5E4 — Даташит
СерияOPA4234
МодельOPA4234U/2K5E4
Маломощные прецизионные операционные усилители с однополярным питанием 14-SOIC от -40 до 85
OPA234, 2234, 4234: Low Power, Precision Single-Supply Operational Amplifiers datasheet
PDF, 1.0 Мб, Версия: B, Файл опубликован: 10 апр 2008
OPA4234U/2K5E4по запросу
Pin14
Package TypeD
Width (мм)3.91
Length (мм)8.65
Thickness (мм)1.58
Max Height (мм)1.75
Additional FeaturesN/A
Approx. Price (US$)4.63 | 1ku
АрхитектураBipolar
CMRR(Min)(dB)86
CMRR(Typ)(dB)106
GBW(Typ)(MHz)0.35
Input Bias Current(Max)(pA)30000
Iq per channel(Max)(mA)0.3
Iq per channel(Typ)(mA)0.25
Number of Channels(#)4
Offset Drift(Typ)(uV/C)0.5
Operating Temperature Range(C)-40 to 85
Output Current(Typ)(mA)11
Rail-to-RailIn to V-
Out
Slew Rate(Typ)(V/us)0.2
Total Supply Voltage(Max)(+5V=5, +/-5V=10)36
Total Supply Voltage(Min)(+5V=5, +/-5V=10)2.7
Vn at 1kHz(Typ)(nV/rtHz)25
Vos (Offset Voltage @ 25C)(Max)(mV)0.1
RoHSНе совместим
  • Remove the DC Portion of Signals with the ADS7817
    PDF, 55 Кб, Файл опубликован: 27 сен 2000
    Unwanted portions of a signal, such as a DC pedestal, can be difficult to reject in a single supply circuit. A DC pedestal voltage most typically appears at the output of an operational amplifier with a small signal riding on top of it. This pedestal voltage is required in the analog domain to insure that the small signal that contains the pertinent information never falls below the ground potenti
На английском языке: Datasheet Texas Instruments OPA4234U/2K5E4
