Datasheet Texas Instruments BQ4845S-A4TRG4 — Даташит
СерияBQ4845
МодельBQ4845S-A4TRG4
RTC IC W Управление NVSRAM, сторожевой таймер, сброс uP, прерывания и предупреждение о низком заряде батареи 28-SOIC 0–70
Parallel RTC With CPU Supervisor datasheet
PDF, 1.6 Мб, Файл опубликован: 5 сен 1999
Pin28
Package TypeDW
Width (мм)7.5
Length (мм)17.9
Thickness (мм)2.35
Max Height (мм)2.65
RoHSНе совместим
  • U-502 Time-Base Oscillator for RTC IC
    PDF, 313 Кб, Файл опубликован: 5 сен 1999
    Time-Base Oscillator for RTC ICs.The operation of the time-base oscillator is critical to the timekeeping functions of the bq3285, bq4285, and bq4845 series of real-time-clocks (RTCs). This application note describes some basic characteristics of the piezoelectric crystal and the on-chip crystal oscillator circuitry designed into these RTC series. It also includes suggestions for achieving timek
  • U-500 Using the bq4845 for a Low-Cost RTC/NVSRAM Subsystem
    PDF, 332 Кб, Файл опубликован: 5 сен 1999
    Using the bq4845 for a Low-Cost RTC/NVSRAM Subsystem.The bq4845 combines on one IC a low-power real-time clock (RTC), a microcontroller supervisor, and a nonvolatile control circuit for static RAM. The part is the basis of a low-cost, reliable RTC plus nonvolatile SRAM subsystem for many embedded applications. This application note discusses the key aspects of bq4845 operation: component sele
  • Semiconductors > Clock and Timing > Real-time Clocks
BQ4845SA4TRG4, BQ4845S A4TRG4
На английском языке: Datasheet Texas Instruments BQ4845S-A4TRG4
