Datasheet Texas Instruments DRV8872DDARQ1 — Даташит
СерияDRV8872-Q1
МодельDRV8872DDARQ1
Драйвер матового двигателя постоянного тока 3,6 А для автомобильной промышленности с функцией оповещения о неисправностях 8-SO PowerPAD от -40 до 125
DRV8872-Q1 Automotive 3.6-A Brushed DC Motor Driver With Fault Reporting datasheet
PDF, 1.2 Мб, Файл опубликован: 30 ноя 2016
Package TypeDDA
Industry STD TermHSOIC
Package QTY2500
Маркировка8872Q
Width (мм)3.9
Length (мм)4.89
Thickness (мм)1.48
Max Height (мм)1.7
Additional FeaturesCurrent Regulation
Control I/FPWM
Number of Full Bridges1
Number of Half Bridges2
Package GroupSO PowerPAD
Package Size: mm2:W x L8SO PowerPAD: 29 mm2: 6 x 4.9(SO PowerPAD) PKG
Peak Output Current3.6 A
RDS(ON) (HS + LS)565 mOhms
RMS Output Current2 A
RatingAutomotive
Vs(Max)45 В
Vs(Min)6.5 В
  • Evaluation Modules & Boards: DRV8872EVM
    DRV8872 H-Bridge PWM Motor Driver Evaluation Module
  • Operating an Engine-Grille Shutter Motor With DRV8872-Q1
    PDF, 1.5 Мб, Файл опубликован: 1 дек 2016
    The addition of an active grille shutter is a key aerodynamic improvement in recent model-year vehicles. Depending on the ambient temperature of the environment, the shutters behind the engine grille can open and close to increase the engine efficiency and reduce turbulent air from entering the engine, thereby reducing drag. The shutters can be operated by a brushed-DC (BDC) motor. A suitable devi
Серия: DRV8872-Q1 (1)
  • DRV8872DDARQ1
  • Semiconductors > Motor Drivers > Brushed DC (BDC) Drivers > Brushed DC Drivers with FETs
На английском языке: Datasheet Texas Instruments DRV8872DDARQ1
