Datasheet Texas Instruments LMV981MF/NOPB — Даташит
СерияLMV981-N
МодельLMV981MF/NOPB
Одиночные операционные усилители RRIO 1,8 В с отключением 6-SOT-23 от -40 до 125
LMV98x-N Small, Low-Power, 1.8-V RRIO Operational Amplifiers With Shutdown datasheet
PDF, 1.6 Мб, Версия: M, Файл опубликован: 30 сен 2016
Pin6
Package TypeDBV
Industry STD TermSOT-23
Package QTY1000
МаркировкаA78A
Width (мм)1.6
Length (мм)2.9
Thickness (мм)1.2
Pitch (мм).95
Max Height (мм)1.45
Additional FeaturesShutdown
АрхитектураBipolar
CMRR(Min)60 дБ
CMRR(Typ)86 дБ
GBW(Typ)1.5 МГц
Input Bias Current(Max)35000 pA
Iq per channel(Max)0.23 мА
Iq per channel(Typ)0.116 мА
Количество каналов1
Offset Drift(Typ)5.5 uV/C
Output Current(Typ)65 мА
Package GroupSOT-23
Package Size: mm2:W x L6SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) PKG
Rail-to-RailIn,Out
Slew Rate(Typ)0.42 V/us
Total Supply Voltage(Max)5 +5V=5, +/-5V=10
Total Supply Voltage(Min)1.8 +5V=5, +/-5V=10
Vn at 1kHz(Typ)50 нВ/rtГц
Vos (Offset Voltage @ 25C)(Max)4 мВ
  • AN-1515 A Comprehensive Study of the Howland Current Pump (Rev. A)
    PDF, 165 Кб, Версия: A, Файл опубликован: 26 апр 2013
    It is well known to analog experts that you can use the positive and negative inputs of an operationalamplifier to make a high-impedance current source (current pump) using a conventional operationalamplifier (op amp). This basic circuit can put out both + and - output current (or zero current) into variousloads. The theory is simple. But the practical problems involved are not so simple or
  • AN-1684 Saving Power in an AC-Coupled Amplifier Circuit (Rev. A)
    PDF, 99 Кб, Версия: A, Файл опубликован: 26 апр 2013
    AC-coupled circuits are often used for single supply operation to bring the input voltage into the inputrange of the amplifier. This circuit topology can be used in AC smoke detectors or in AC proximitysensors.
На английском языке: Datasheet Texas Instruments LMV981MF/NOPB
