Клеммники KEEN SIDE
Datasheet Texas Instruments LMH6522SQ/NOPB — Даташит
СерияLMH6522
МодельLMH6522SQ/NOPB
Высокопроизводительный четырехъядерный DVGA 54-WQFN от -40 до 85
LMH6522 High Performance Quad DVGA datasheet
PDF, 1.4 Мб, Версия: D, Файл опубликован: 18 мар 2013
Pin54
Package TypeNJY
Industry STD TermWQFN
JEDEC CodeR-PQFP-N
Package QTY2000
МаркировкаL6522
Width (мм)5.5
Length (мм)10
Thickness (мм).8
Pitch (мм).5
Max Height (мм).8
Acl, min spec gain0.61 V/V
BW @ Acl1400 МГц
Max Gain26 дБ
Количество каналов4
PGA/VGAVGA
Package GroupWQFN
Package Size: mm2:W x L54WQFN: 55 mm2: 5.5 x 10(WQFN) PKG
Vs(Max)5.25 В
Vs(Min)4.75 В
  • Evaluation Modules & Boards: LMH6522EVAL
    LMH6522EVAL Evaluation Module
  • AN-2235 Ckt Brd Design for LMH6517/21/22 & Other H-Sp IF/RF F Amp (Rev. A)
    PDF, 3.2 Мб, Версия: A, Файл опубликован: 1 май 2013
    High-bandwidth, high-performance amplifiers require care in board layout techniques in order to ensureoptimum performance. This paper will address the key components of PCB design for high-performanceamplifiers, including the new LMH6521 and LMH6522 DVGAs.
  • A Walk Along the Signal Path (High-Speed Signal Path)
    PDF, 461 Кб, Файл опубликован: 30 мар 2005
  • Using High Speed Diff Amp to Drive ADCs (Rev. A)
    PDF, 175 Кб, Версия: A, Файл опубликован: 26 апр 2013
    The right high speed differential amplifier will add flexibility to signal chains that include a high speedanalog-to-digital converter (ADC). A differential amplifier can provide signal conditioning such as singleended to differential conversion, impedance transformation, and gain or attenuation.
  • AN-1719 Noise Figure Analysis Fully Differential Amplifier (Rev. A)
    PDF, 97 Кб, Версия: A, Файл опубликован: 1 май 2013
    This application note provides noise figure analysis for fully differential amplifiers, including output noisecalculation and noise figure calculation.
  • Between the Amplifier and ADC: Managing Filter Loss in Communications Systems (Rev. B)
    PDF, 114 Кб, Версия: B, Файл опубликован: 26 апр 2013
    This application report discusses managing filter loss in communications systems.
  • AN-1718 Differential Amplifier Applications Up to 400 MHz (Rev. B)
    PDF, 73 Кб, Версия: B, Файл опубликован: 1 май 2013
    The LMH6515 is a fully differential amplifier optimized for signal path applications up to 400 MHz and hasa 200О© input.
Серия: LMH6522 (2)
  • Semiconductors > Amplifiers > Programmable & Variable Gain Amplifiers (PGA/VGA)
На английском языке: Datasheet Texas Instruments LMH6522SQ/NOPB
