Datasheet Texas Instruments SN74LVT125PWG4 — Даташит
СерияSN74LVT125
МодельSN74LVT125PWG4
Буферы с четырьмя шинами ABT, 3,3 В, с выходами с 3 состояниями, 14-TSSOP от -40 до 85
SN74LVT125 datasheet
PDF, 673 Кб, Версия: F, Файл опубликован: 13 окт 2003
IC BUF NON-INVERT 3.6V 14TSSOP. Buffer, Non-Inverting 4 Element 1 Bit per Element 3-State Output 14-TSSOP. Logic - Buffers, Drivers, Receivers,...
SN74LVT125PWG4
48 ₽
Элитан
SN74LVT125PWG4
700 ₽
Hi-Tech Circuit Group
SN74LVT125PWG4
SN74LVT125PWG4
Pin14
Package TypePW
Industry STD TermTSSOP
Package QTY90
МаркировкаLX125
Width (мм)4.4
Length (мм)5
Thickness (мм)1
Max Height (мм)1.2
Bits4
F @ Nom Voltage(Max)100 Mhz
ICC @ Nom Voltage(Max)0.007 мА
Output Drive (IOL/IOH)(Max)-32/64 мА
Package GroupTSSOP
Package Size: mm2:W x L14TSSOP: 32 mm2: 6.4 x 5(TSSOP) PKG
Schmitt TriggerNo
Technology FamilyLVT
VCC(Max)3.6 В
VCC(Min)2.7 В
Voltage(Nom)3.3 В
tpd @ Nom Voltage(Max)4 нс
  • LVT Family Characteristics (Rev. A)
    PDF, 98 Кб, Версия: A, Файл опубликован: 1 мар 1998
    To address the need for a complete low-voltage interface solution, Texas Instruments has developed a new generation of logic devices capable of mixed-mode operation. The LVT series relies on a state-of-the-art submicron BiCMOS process to provide up to a 90% reduction in static power dissipation over ABT. LVT devices solve the system need for a transparent seam between the low-voltage and 5-V secti
  • LVT-to-LVTH Conversion
    PDF, 84 Кб, Файл опубликован: 8 дек 1998
    Original LVT devices that have bus hold have been redesigned to add the High-Impedance State During Power Up and Power Down feature. Additional devices with and without bus hold have been added to the LVT product line. Design guidelines and issues related to the bus-hold features, switching characteristics, and timing requirements are discussed.
На английском языке: Datasheet Texas Instruments SN74LVT125PWG4
