Datasheet Texas Instruments SN74LVC04ADGVRE4 — Даташит
СерияSN74LVC04A
МодельSN74LVC04ADGVRE4
Шестигранный инвертор 14-TVSOP от -40 до 125
SNx4LVC04A Hex Inverters datasheet
PDF, 1.4 Мб, Версия: T, Файл опубликован: 12 дек 2016
26 предложений от 10 поставщиков
Микросхема Логический чип, TEXAS INSTRUMENTS SN74LVC04ADGVRE4 Inverter, 74LVC04, 1Input, 24mA, 1.65V to 3.6V, TVSOP-14
SN74LVC04ADGVRE4
9.35 ₽
Зенер
Россия и страны ТС
SN74LVC04ADGVRE4
от 15 ₽
SN74LVC04ADGVRE4
62 ₽
SN74LVC04ADGVRE4
Pin14
Package TypeDGV
Industry STD TermTVSOP
Package QTY2000
МаркировкаLC04A
Width (мм)4.4
Length (мм)3.6
Thickness (мм)1.05
Pitch (мм).4
Max Height (мм)1.2
Bits6
F @ Nom Voltage(Max)100 Mhz
ICC @ Nom Voltage(Max)0.01 мА
Output Drive (IOL/IOH)(Max)-24/24 мА
Package GroupTVSOP
Package Size: mm2:W x L14TVSOP: 23 mm2: 6.4 x 3.6(TVSOP) PKG
Schmitt TriggerNo
Technology FamilyLVC
VCC(Max)3.6 В
VCC(Min)1.65 В
Voltage(Nom)1.8,2.5,2.7,3.3 В
tpd @ Nom Voltage(Max)8,7.5,5.5,4.5 нс
  • LVC Characterization Information
    PDF, 114 Кб, Файл опубликован: 1 дек 1996
    This document provides characterization information about low-voltage logic (LVL) that operates from a 3.3-V power supply. It addresses the issues of interfacing to 5-V logic ac performance power considerations input and output characteristics and signal integrity for this family of devices.
  • Use of the CMOS Unbuffered Inverter in Oscillator Circuits
    PDF, 796 Кб, Файл опубликован: 6 ноя 2003
    CMOS devices have a high input impedance high gain and high bandwidth. These characteristics are similar to ideal amplifier characteristics and hence a CMOS buffer or inverter can be used in an oscillator circuit in conjunction with other passive components. Now CMOS oscillator circuits are widely used in high-speed applications because they are economical easy to use and take significantly
  • Semiconductors > Logic > Buffer/Driver/Transceiver > Inverting Buffer/Driver
На английском языке: Datasheet Texas Instruments SN74LVC04ADGVRE4
