Datasheet Texas Instruments CD54HC160F3A — Даташит
СерияCD54HC160
МодельCD54HC160F3A
Высокоскоростные синхронные десятичные счетчики BCD с логикой КМОП, асинхронный сброс 16-CDIP от -55 до 125
Datasheet
TSP
Pin16
Package TypeJ
Industry STD TermCDIP
JEDEC CodeR-GDIP-T
Width (мм)6.92
Length (мм)19.56
Thickness (мм)4.57
Pitch (мм)2.54
Max Height (мм)5.08
RoHSНе совместим
  • Selecting the Right Texas Instruments Signal Switch
    PDF, 769 Кб, Файл опубликован: 7 сен 2001
    Texas Instruments offers a wide variety of electronic switches (digital analog bilateral bilateral analog) in a variety of families including CBT CBTLV HC LV and LVC. Depending on the application the right solution may be an analog switch that passes digital signals or vice versa. This application report summarizes the various switching technologies and provides considerations for choosi
Серия: CD54HC160 (1)
  • CD54HC160F3A
  • Semiconductors > Space & High Reliability > Logic Products > Specialty Logic Products > Counter/Arithmetic/Parity Function Products
На английском языке: Datasheet Texas Instruments CD54HC160F3A
