Datasheet Texas Instruments TMS320C5420PGEA200 — Даташит
СерияTMS320VC5420
МодельTMS320C5420PGEA200
Процессор цифровых сигналов 144-LQFP от 0 до 0
TMS320VC5420 Fixed-Point Digital Signal Processor datasheet
PDF, 1.2 Мб, Версия: F, Файл опубликован: 22 окт 2008
Pin144
Package TypePGE
Industry STD TermLQFP
JEDEC CodeS-PQFP-G
МаркировкаC5420PGEA200
Width (мм)20
Length (мм)20
Thickness (мм)1.4
Pitch (мм).5
Max Height (мм)1.6
  • Evaluation Modules & Boards: TMDSDSK5416
    TMS320C5416 DSP Starter Kit (DSK)
  • Interfacing the PCI2040 to the TMS320VC5420 DSP
    PDF, 86 Кб, Файл опубликован: 28 июн 2000
    This application note describes how system designers can interface the TMS320VC5420 16-bit HPI (C5420) to the PCI bus, using the TMS320C6x HPI (C6x) mode interface on the PCI2040 PCI-to-DSP bridge. The note specifies two modes for mapping the C5420 to host memory, depending on the number of C5420s. The note also describes both hardware and software considerations, provides an example schematic, an
  • TPS6010x/TPS6011x Charge Pump (Rev. A)
    PDF, 391 Кб, Версия: A, Файл опубликован: 16 дек 1999
    Charge pumps are dc/dc converters that use a capacitor instead of an inductor or transformer for energy storage. They are able to generate positive or negative voltages from the input voltage. The input voltage can be multiplied by some factor such as 0.5, 2, 3, and so on, to generate the output voltage desired. Often, charge pumps and all related parts (including those used for energy storage) ar
  • Semiconductors > Processors > Digital Signal Processors > C5000 DSP > Other C5000 DSP
На английском языке: Datasheet Texas Instruments TMS320C5420PGEA200
