Оптопары и оптореле Megawin
Datasheet Texas Instruments UC3875DWP — Даташит
СерияUC3875
МодельUC3875DWP
Резонансный регулятор фазового сдвига 28-SOIC от 0 до 70
Phase Shift Resonant Controller datasheet
PDF, 5.7 Мб, Версия: C, Файл опубликован: 24 май 2007
Pin28
Package TypeDW
Package QTY20
МаркировкаUC3875DWP
Width (мм)7.5
Length (мм)17.9
Thickness (мм)2.35
Max Height (мм)2.65
  • Evaluation Modules & Boards: UCC3895EVM-001
    UCC3895 Evaluation Module
  • A Comparison Between the BiCMOS UCC3895 Phase Shift Controller and the UC3875
    PDF, 21 Кб, Файл опубликован: 22 фев 2001
    This application report compares the BiCMOS UCC3895 to its bipolar predecessors, the UC3875/6/7/8 family and the UC3879 controller. All of these integrated circuits provide the control and drive signals needed to implement a full-bridge converter using phase-shifted control. The UCC3895 represents the latest offering in the Texas Instruments line of phase-shift controllers, incorporating a feature
  • DN-63 The Current-Doubler Rectifier: An Alternative Rectification Technique
    PDF, 81 Кб, Файл опубликован: 12 янв 2001
    The UC3875, UC3879, and UC3895 families of ICs control a bridge power stage by phase-shifting the switching of one half-bridge with respect to the other. This method allows constant-frequency pulse-width modulation in combination with resonant, zero-voltage switching for high efficiency performance. These ICs can be configured to provide control in either voltage mode or current mode operation, wi
  • Phase Shifted Full Bridge, Zero Voltage Transition Design Considerations (Rev. A)
    PDF, 393 Кб, Версия: A, Файл опубликован: 22 янв 2011
    This Application Note will highlight the design considerations incurred in a high frequency power supply using the Phase Shifted Resonant PWM control technique. An overview of this switching technique including comparisons to existing fixed frequency non-resonant and variable frequency Zero Voltage Switching is included. Numerous design equations and associated voltage, current and timing waveform
  • Synchronous Rectifiers of a Current Doubler
    PDF, 207 Кб, Файл опубликован: 27 фев 2003
    Driving a current doubler synchronous rectification output stage can be a very complex task, especially for a phase shifted full bridge topology. However, using the A and B outputs of the UCC3895 along with the UCC37324 dual 4-A MOSFET driver, direct PWM control of a synchronous rectifier current doubler output stage achieves. This technique provides the proper gating and timing signals necessary
  • Current Doubler Rectifier Offers Ripple Current Cancellation
    PDF, 116 Кб, Файл опубликован: 21 сен 2004
  • Semiconductors > Power Management > Offline and Isolated DC/DC Controllers and Converters > PWM and Resonant Controller
На английском языке: Datasheet Texas Instruments UC3875DWP
