Datasheet Texas Instruments SN74CBT6800APWRG4 — Даташит
Серия | SN74CBT6800A |
Модель | SN74CBT6800APWRG4 |
10-битный коммутатор шины на полевом транзисторе с предварительно заряженными выходами 24-TSSOP от -40 до 85
10-Bit FET Bus Switch With Precharged Outputs datasheet
PDF, 752 Кб, Версия: N, Файл опубликован: 15 мар 2001
Pin | 24 |
Package Type | PW |
Industry STD Term | TSSOP |
JEDEC Code | R-PDSO-G |
Package QTY | 2000 |
Carrier | LARGE T&R |
Маркировка | CT6800A |
Width (мм) | 4.4 |
Length (мм) | 7.8 |
Thickness (мм) | 1 |
Pitch (мм) | .65 |
Max Height (мм) | 1.2 |
Mechanical Data | Скачать |
Additional Features | Pre-charged signal path |
Полоса частот | 200 МГц |
Configuration | 1:1 SPST |
Input/Ouput Voltage(Max) | 5.5 В |
Input/Output Continuous Current(Max) | 128 мА |
Input/Output OFF-state Capacitance(Typ) | 4.5 пФ |
Количество каналов | 10 |
OFF-state leakage current(Max) | 5 мкА |
ON-state leakage current(Max) | 5 мкА |
Package Group | TSSOP |
Package Size: mm2:W x L | 24TSSOP: 50 mm2: 6.4 x 7.8(TSSOP) PKG |
Rating | Catalog |
Ron(Max) | 20 Ohms |
Ron(Typ) | 3 Ohms |
Supply Current(Max) | 3 uA |
Supply Range | 5.5 Max |
VIH(Min) | 2 В |
VIL(Max) | 0.8 В |
Vdd(Max) | 5.5 В |
Vdd(Min) | 4 В |
Vss(Max) | N/A В |
Vss(Min) | N/A В |
- FET Switches in Docking StationsPDF, 92 Кб, Файл опубликован: 23 июл 2003
Docking stations for portable electronics require the capability to connect a system with a live-running bus to a disabled or powered-down system. This hot-docking event must not cause any electrical damage, electrical signal glitches, or data corruption. This application report explains the use of TI FET bus-switch products with precharge to accomplish this connection. - Flexible Voltage-Level Translation With CBT Family DevicesPDF, 40 Кб, Файл опубликован: 20 июл 1999
Voltage translation between buses with incompatible logic levels can be accomplished using Texas Instruments (TI) translation-voltage clamps (TVC) or standard crossbar technology (CBT) devices. CBT devices in this application offer flexibility in designs, protection of circuits that are sensitive to high-state voltage-level overshoots, and cost efficiency. - 5-V To 3.3-V Translation With the SN74CBTD3384 (Rev. B)PDF, 35 Кб, Версия: B, Файл опубликован: 1 мар 1997
The emergence of low-voltage technology required existing 5-V systems to interact with 3.3-V systems. Compatibility issues of mixed-mode operation created the need for 5-V to 3.3-V translation. Buffers and transceivers serve as effective translators. While providing additional drive, these devices also add propagation delay and require directional control. In cases where additional drive is not - 3.3-V to 2.5-V Translation with Texas Instruments Crossbar Technology (Rev. A)PDF, 32 Кб, Версия: A, Файл опубликован: 3 апр 1998
- VOLTAGE LEVEL TRANSLATION (SL) - FamilyPDF, 111 Кб, Файл опубликован: 21 сен 2011
- Bus FET Switch Solutions for Live Insertion ApplicationsPDF, 300 Кб, Файл опубликован: 7 фев 2003
Серия: SN74CBT6800A (4)
- SN74CBT6800ADW SN74CBT6800ADWR SN74CBT6800APWR SN74CBT6800APWRG4
- Semiconductors > Switches and Multiplexers > Analog Switches/Muxes
