Datasheet ТI THS6072ID — Даташит
СерияTHS6072
МодельTHS6072ID
Datasheet Texas Instruments THS6072ID
Дифференциальный приемник ADSL малой мощности 8-SOIC от -40 до 85
Low-Power ADSL Differntial Receivers datasheet
PDF, 1.2 Мб, Версия: B, Файл опубликован: 25 июн 2001
  • Active Output Impedance for ADSL Line Drivers
    PDF, 636 Кб, Файл опубликован: 26 ноя 2002
    Signal termination is very common in bidirectional communication systems. Termination allows for receiving signals while transmitting different signals at the same time. With the increasing popularity of asymmetrical digital subscriber lines (ADSL), the requirement for a low power line driver amplifier combined with line termination becomes a very difficult goal. This application note examines the
На английском языке: Datasheet Texas Instruments THS6072ID
Политика конфиденциальности
