Линейка продуктов KEEN SIDE
Datasheet Texas Instruments TMS320DM365ZCEF — Даташит
СерияTMS320DM365
МодельTMS320DM365ZCEF
Цифровой медиапроцессор DaVinci 338-NFBGA от 0 до 85
TMS320DM365 Digital Media System-on-Chip datasheet
PDF, 1.5 Мб, Версия: E, Файл опубликован: 1 июл 2011
Pin338338
Package TypeZCEZCE
Industry STD TermNFBGANFBGA
JEDEC CodeS-PBGA-NS-PBGA-N
Package QTY160160
CarrierJEDEC TRAY (5+1)JEDEC TRAY (5+1)
МаркировкаDM365ZCE30F570
Width (мм)1313
Length (мм)1313
Thickness (мм).89.89
Pitch (мм).65.65
Max Height (мм)1.31.3
ARM CPU1 ARM9
ARM MHz300 Max.
ApplicationsConsumer Electronics,Industrial Cameras,Security, Video and Imaging, Portable Cameras,Video Surveillance IP Cameras
DRAMLPDDR,DDR2
EMAC10/100
I2C1
Operating SystemsLinux
Рабочий диапазон температурот -40 до 85,0 до 85 C
Pin/Package338NFBGA
SPI5
UART2 SCI
USBUSB2.0,HS,OTG
Video Acceleration1 MJCP,1 HDVICP
Video Port1 Dedicated Input,1 Dedicated Output Configurable
Video Resolution/Frame Rate720P,30 FPS
  • Development Kits: DLPLIGHTCRAFTER
    DLPВ® LightCrafterВ™ Evaluation Module
  • Evaluation Modules & Boards: TMDXEVM368
    TMS320DM36x Evaluation Module
    XDS200 USB Debug Probe
  • Understanding H.264 Decoder Buffer Mechanism for TMS320DM365
    PDF, 78 Кб, Файл опубликован: 4 дек 2009
    With XDM1.0, the decoder does not have separate reference and display buffers. The reference buffers of the decoder are used for display as well. This helps in reducing the overall DDR utilization and DDR b/w.However, this new arrangement changes the overall buffer management of the application. Now the application needs to manage the display and reference buffers using the new XDM 1.0 APIs. Thi
  • Application Parameter Settings for TMS320DM365 H.264 Encoder
    PDF, 82 Кб, Файл опубликован: 29 апр 2010
    Texas Instrument's TMS320DM365 H.264 video encoder is a flexible implementation of the H.264 video encoder standard. It supports various profiles and features, each of which can be independently selected, set or controlled. This flexibility enables the TMS320DM365 H.264 video encoder to be used in a variety of different applications. This application report lists the different parameters that can
  • Smart Codec Features in TMS320DM365
    PDF, 75 Кб, Файл опубликован: 9 дек 2009
    You will significantly enhance video encoder quality by incorporating external input/feedback from the system. Additionally, the robustness of the video codec will also be vastly improved. The video codec can utilize such information to react quickly and adapt to changing dynamics of the input video signal. This greatly enhances the end-user experience as the video encoder can prioritize the more
  • TMS320DM365 Preview of Codec Porting on Linux
    PDF, 99 Кб, Файл опубликован: 4 дек 2009
    TI codec software was traditionally run on a DSP, which had DSP/BIOSв„ў software kernel foundation as an operating system. With the new range of upcoming SOCs , where the architecture is getting more hardware accelerator centric, the use of digital signal processing (DSP) is reduced. The codec can operate directly from the main processor, which also hosts the primary operating system. Theref
  • TMS320DM36x Power Consumption Summary
    PDF, 61 Кб, Файл опубликован: 10 сен 2009
    This application report discusses the power consumption of the Texas Instruments TMS320DM36x digital media System-on-Chip (DMSoC). Power consumption on the DM36x device is highly application-dependent; therefore, a spreadsheet that estimates power consumption is provided along with this document. To obtain good results from the spreadsheet, realistic usage parameters must be entered (see Section 2
  • Powering the TMS320DM365 using the TPS650061
    PDF, 311 Кб, Файл опубликован: 10 май 2012
  • Migrating From TMS320DM35x to TMS320DM36x Devices (Rev. A)
    PDF, 79 Кб, Версия: A, Файл опубликован: 2 июн 2011
    For purposes of comparison, this application report describes the key features of the TMS320DM36x (DM36x) and the TMS320DM35x (DM35x) digital media processors.
  • TMS320DM365 to TMS320DM368 Migration Guide
    PDF, 35 Кб, Файл опубликован: 11 апр 2010
  • High Integration, High Efficiency Power Solution using DCDC Converters for DM365 (Rev. A)
    PDF, 125 Кб, Версия: A, Файл опубликован: 11 сен 2009
  • TMS320DM36x SoC Architecture and Throughput
    PDF, 5.8 Мб, Файл опубликован: 29 июл 2009
    This application report provides information on the DM36x throughput performance and describes the DM36x System-on-Chip (SoC) architecture, data path infrastructure, and constraints that affect the throughput and different optimization techniques for optimum system performance. This document also provides information on the maximum possible throughput performance of different peripherals on the So
  • Simple Power Solution Using LDOs for the DM365 (Rev. A)
    PDF, 104 Кб, Версия: A, Файл опубликован: 11 сен 2009
  • LSP 2.10 DaVinci Linux Drivers (Rev. A)
    PDF, 1.2 Мб, Версия: A, Файл опубликован: 8 июл 2009
  • High-Vin, High-Efficiency Power Solution Using DC/DC Converter for the DM365
    PDF, 165 Кб, Файл опубликован: 4 авг 2009
    TMS320DM365,TPS62111,TPS62290,TPS62231 High-Vin, High-Efficiency Power Solution Using DC/DC Converter for TMS320DM365
  • High-Efficiency Power Solution Using DC/DC Converter for the DM365 (Rev. A)
    PDF, 151 Кб, Версия: A, Файл опубликован: 11 сен 2009
  • Understanding TI's PCB Routing Rule-Based DDR Timing Specification (Rev. A)
    PDF, 93 Кб, Версия: A, Файл опубликован: 17 июл 2008
    This application report motivates the way the DDR high-speed timing requirements are now going to be communicated to system designers. The traditional method of using data sheet parameters and simulation models is tedious. The system designer uses this information to evaluate whether timing specifications are met and can be expected to operate reliably.Ultimately, the real question the hardwa
  • High-Speed Interface Layout Guidelines (Rev. G)
    PDF, 814 Кб, Версия: G, Файл опубликован: 27 июл 2017
    As modern bus interface frequencies scale higher, care must be taken in the printed circuit board (PCB) layout phase of a design to ensure a robust solution.
  • Semiconductors > Processors > Digital Signal Processors > Media Processors > Digital Video Processors
На английском языке: Datasheet Texas Instruments TMS320DM365ZCEF
