Datasheet Texas Instruments SG3524NSR — Даташит
СерияSG3524
МодельSG3524NSR
Регулирующие широтно-импульсные модуляторы 16-SO от 0 до 70
SGx524 Regulating Pulse-Width Modulators datasheet
PDF, 1.5 Мб, Версия: E, Файл опубликован: 27 янв 2015
Pin16
Package TypeNS
Industry STD TermSOP
Package QTY2000
МаркировкаSG3524
Width (мм)5.3
Length (мм)10.3
Thickness (мм)1.95
Max Height (мм)2
Control MethodVoltage
Duty Cycle(Max)45 %
Frequency(Max)722 kHz
Frequency(Min)0.13 kHz
Gate Drive(Typ)0.05 A
Package GroupSO
Special FeaturesAdjustable Switching Frequency,Error Amplifier,Multi-topology
TopologyBoost,Buck,Flyback,Forward,Full-Bridge,Half-Bridge,Push-Pull
UVLO Thresholds On/OffN/A В
Vin(Max)40 В
Vin(Min)8 В
  • Understanding Buck Power Stages In Switchmode Power Supplies
    PDF, 173 Кб, Файл опубликован: 4 мар 1999
    A switching power supply consists of the power stage and the control circuit. The power stage performs the basic power conversion from the input voltage to the output voltage and includes switches and the output filter. This report addresses the buck power stage only and does not cover control circuits. Detailed steady-state and small-signal analysis of the buck power stage operating in continuous
  • Understanding Boost Power Stages In Switchmode Power Supplies
    PDF, 149 Кб, Файл опубликован: 4 мар 1999
    A switching power supply consists of the power stage and the control circuit. The power stage performs the basic power conversion from the input voltage to the output voltage and includes switches and the output filter. This report addresses the boost power stage only and does not cover control circuits. The report includes detailed steady-stage and small-signal analysis of the boost power stage o
  • Understanding Buck-Boost Power Stages in Switchmode Power Supplies (Rev. A)
    PDF, 363 Кб, Версия: A, Файл опубликован: 28 май 2002
  • Semiconductors > Power Management > Offline and Isolated DC/DC Controllers and Converters > PWM and Resonant Controller
На английском языке: Datasheet Texas Instruments SG3524NSR
Публикации по теме
