Datasheet Texas Instruments UC2833DWG4 — Даташит
СерияUC2833
МодельUC2833DWG4
Прецизионные линейные контроллеры с низким падением напряжения 16-SOIC от -40 до 85
Precision Low Dropout Linear Controllers datasheet
PDF, 1.6 Мб, Версия: A, Файл опубликован: 3 июн 2003
Pin16
Package TypeDW
Package QTY40
МаркировкаUC2833DW
Width (мм)7.5
Length (мм)10.3
Thickness (мм)2.35
Max Height (мм)2.65
Fixed Output Options2 В
Iq(Typ)3.3 мА
Output OptionsFixed Output
Package Size: mm2:W x L16SOIC: 106 mm2: 10.3 x 10.3(SOIC) PKG
Thermal Resistance ОёJA65 В°C/W
Vin(Max)36 В
Vin(Min)4.5 В
Vout(Max)35 В
Vout(Min)2 В
  • U-152 A High-Performance Linear Regulator for Low Dropout Applications
    PDF, 172 Кб, Файл опубликован: 5 сен 1999
    The UC3832 and UC3833 series of precision linear regulators includes all the control functions required in the design of very low dropout linear regulators. Also, they feature an innovative duty-ratio current-limiting technique that provides peak load capability while limiting the average power dissipation of the external-pass transistor during fault conditions. A linear regulator design offers se
  • DN-32 Optocoupler Feedback Drive Techniques
    PDF, 90 Кб, Файл опубликован: 5 сен 1999
    This design note describes ways to drive an optocoupler. One of the most popular is to use a TL431 Adjustable-Shunt Regulator. However a regulator-control lC-such as the UC3832 UC3833 or UC3836 substituted for the TL43431-provides numerous additional features besides regulating the output. Overcurrent limiting and fault-protection handshaking with external control logic and the introduction of
Серия: UC2833 (4)
  • Semiconductors > Power Management > Linear Regulator (LDO) > LDO Controller (External FET)
На английском языке: Datasheet Texas Instruments UC2833DWG4
