Datasheet Texas Instruments PCA9548ADGV — Даташит
СерияPCA9548A
МодельPCA9548ADGV
8-канальный переключатель I2C со сбросом 24-TVSOP от -40 до 85
PCA9548A Low Voltage 8-Channel I2C Switch With Reset datasheet
PDF, 1.2 Мб, Версия: E, Файл опубликован: 3 фев 2015
Pin24
Package TypeDGV
Industry STD TermTVSOP
Width (мм)4.4
Length (мм)5
Thickness (мм)1.05
Pitch (мм).4
Max Height (мм)1.2
Channel Width8
I2C Address1110 xxx
Package GroupTVSOP
Simultaneously Active Channels1 to 8
Special FeaturesReset Input,5V Tolerant I/O
VCC(Max)5.5 В
VCC(Min)2.3 В
fSCLK(Max)0.4 МГц
tpd max1 нс
RoHSНе совместим
  • Evaluation Modules & Boards: TCA9548AEVM
    TCA9548AEVM: I2C 1-to-8 Bidirectional Translating Switch Evaluation Module
  • Programming Fun Lights With TI's TCA6507
    PDF, 109 Кб, Файл опубликован: 30 ноя 2007
  • Choosing the Correct I2C Device for New Designs
    PDF, 87 Кб, Файл опубликован: 7 сен 2016
    The I2C bus is a very popular and powerful bus used for communication between a single (or multiple)master and a single (or multiple) slave device. In many applications there is a potential need for moreslave devices on the bus, isolation between similar addressed slaves, or a need for more I/Os. Theseneeds can be solved with an I2C buffer, switch, and I/O expander.The application note h
  • Maximum Clock Frequency of I2C Bus Using Repeaters
    PDF, 116 Кб, Файл опубликован: 15 май 2015
    TCA9617 Maximum Allowed Frequency on I2C Bus Using Repeaters
  • I2C Bus Pull-Up Resistor Calculation
    PDF, 157 Кб, Файл опубликован: 13 фев 2015
  • Understanding the I2C Bus
    PDF, 124 Кб, Файл опубликован: 30 июн 2015
  • Semiconductors > Interface > I2C > I2C Switches and Multiplexers
На английском языке: Datasheet Texas Instruments PCA9548ADGV
