Datasheet Texas Instruments DRV10983ZPWPR — Даташит
СерияDRV10983
МодельDRV10983ZPWPR
40 Вт, 24 В, 3-фазный бездатчиковый драйвер двигателя BLDC 24-HTSSOP от -40 до 125
DRV10983 12- to 24-V, Three-Phase, Sensorless BLDC Motor Driver datasheet
PDF, 1.9 Мб, Версия: E, Файл опубликован: 16 май 2017
Pin24
Package TypePWP
Industry STD TermHTSSOP
Package QTY2000
МаркировкаDRV10983Z
Width (мм)4.4
Length (мм)7.8
Thickness (мм)1
Max Height (мм)1.2
Additional Features180 Degree Sinusoidal Commutation,100mA Step Down Buck,Rotor Lock Protection
Control I/FPWM, Analog, or I2C
Number of Half Bridges3
Package GroupHTSSOP
Peak Output Current3 A
RDS(ON) (HS + LS)250 mOhms
RMS Output Current2 A
Vs(Max)28 В
Vs(Min)8 В
  • Evaluation Modules & Boards: DRV10983EVM-TB
    DRV10983EVM Target Board
    DRV10983 Three-Phase Brushless Motor Driver Evaluation Module
  • Speed-Control Techniques in AC-DC Operated BLDC Applications
    PDF, 165 Кб, Файл опубликован: 11 авг 2016
    To achieve energy efficiency, ceiling fans and ventilation fans are moving from simple alternate-current (AC) induction motors to brushless direct-current (DC) motors (BLDC). An AC-operated BLDC motor requires two sections to run the BLDC motor: the AC-DC power conversion section and the DC to 3-phase AC conversion section. The Texas Instruments reference design, TIDA-00652, helps to meet these ch
  • DRV10983EVM-TB Target Board Programming Guide
    PDF, 398 Кб, Файл опубликован: 7 окт 2014
    DRV10983/DRV10975 Programming Guide for the DRV10983/DRV10975
Серия: DRV10983 (4)
  • Semiconductors > Motor Drivers > Brushless DC (BLDC) Drivers > Brushless DC Drivers with FETs
На английском языке: Datasheet Texas Instruments DRV10983ZPWPR
