Datasheet Texas Instruments SN74LVC02ADRG4 — Даташит
СерияSN74LVC02A
МодельSN74LVC02ADRG4
Четверной 2-входной элемент положительного ИЛИ-НЕ 14-SOIC от -40 до 125
SN54LVC02A, SN74LVC02A datasheet
PDF, 1.3 Мб, Версия: Q, Файл опубликован: 26 июл 2005
Pin14
Package TypeD
Package QTY2500
МаркировкаLVC02A
Width (мм)3.91
Length (мм)8.65
Thickness (мм)1.58
Max Height (мм)1.75
Bits4
F @ Nom Voltage(Max)70 Mhz
ICC @ Nom Voltage(Max)0.04 мА
Output Drive (IOL/IOH)(Max)24/-24 мА
Schmitt TriggerNo
Technology FamilyLVC
VCC(Max)3.6 В
VCC(Min)1.5 В
Voltage(Nom)1.8,2.5,2.7,3.3 В
tpd @ Nom Voltage(Max)8.9,7.4,5.4,4.4 нс
  • LVC Characterization Information
    PDF, 114 Кб, Файл опубликован: 1 дек 1996
    This document provides characterization information about low-voltage logic (LVL) that operates from a 3.3-V power supply. It addresses the issues of interfacing to 5-V logic ac performance power considerations input and output characteristics and signal integrity for this family of devices.
  • Use of the CMOS Unbuffered Inverter in Oscillator Circuits
    PDF, 796 Кб, Файл опубликован: 6 ноя 2003
    CMOS devices have a high input impedance high gain and high bandwidth. These characteristics are similar to ideal amplifier characteristics and hence a CMOS buffer or inverter can be used in an oscillator circuit in conjunction with other passive components. Now CMOS oscillator circuits are widely used in high-speed applications because they are economical easy to use and take significantly
  • Semiconductors > Logic > Gate > NOR Gate
На английском языке: Datasheet Texas Instruments SN74LVC02ADRG4
