Datasheet Texas Instruments DAC703KP — Даташит
СерияDAC703
МодельDAC703KP
Pin24
Package TypeNTA
Industry STD TermPDIP
JEDEC CodeR-PDIP-T
Width (мм)13.53
Length (мм)30.99
Thickness (мм)4.06
Pitch (мм)2.54
Max Height (мм)6.35
RoHSНе совместим
  • Superposition: The Hidden DAC Linearity Error
    PDF, 106 Кб, Файл опубликован: 2 окт 2000
    A digital-to analog converter (DAC) translates digital signals to analog signals. For example, a 12-bit DAC takes a 12-bit binary number, called an input code, and converts it into one of 4,096 analog output voltages or currents. When the contribution to the output voltage or current of each individual bit is independent of any other, it means that the device exhibits no superposition error or tha
  • Semiconductors > Data Converters > Digital to Analog Converter > Precision DAC (=<10MSPS)
На английском языке: Datasheet Texas Instruments DAC703KP
