Datasheet Texas Instruments TS5A4596DBVRG4 — Даташит
| Серия | TS5A4596 |
| Модель | TS5A4596DBVRG4 |
Одноканальный аналоговый переключатель SPST 8 Ом 5 В/3,3 В 5-SOT-23 от -40 до 85
Купить TS5A4596DBVRG4 на РадиоЛоцман.Цены — от 5.46 до 29 ₽8 предложений от 8 поставщиков Чип интерфейса, 8Ω SPST 5V/3.3V Single-Channel Analog Switch 5-SOT-23 -40℃ to 85℃ | |||
| TS5A4596DBVRG4 Texas Instruments | 5.46 ₽ | ||
| TS5A4596DBVRG4 Texas Instruments | 19 ₽ | ||
| TS5A4596DBVRG4 Texas Instruments | по запросу | ||
| TS5A4596DBVRG4 | по запросу | ||
| Pin | 5 |
| Package Type | DBV |
| Industry STD Term | SOT-23 |
| JEDEC Code | R-PDSO-G |
| Package QTY | 3000 |
| Carrier | LARGE T&R |
| Маркировка | JSCR |
| Width (мм) | 1.6 |
| Length (мм) | 2.9 |
| Thickness (мм) | 1.2 |
| Pitch (мм) | .95 |
| Max Height (мм) | 1.45 |
| Mechanical Data | Скачать |
| Полоса частот | 450 МГц |
| Bandwidth(Max) | 450 МГц |
| Configuration | 1:1 SPST |
| ESD Charged Device Model | 1 kV |
| ESD HBM | 2 kV |
| Input/Ouput Voltage(Max) | 5.5 В |
| Input/Output Continuous Current(Max) | 20 мА |
| Input/Output OFF-state Capacitance(Typ) | 6.5 пФ |
| Input/Output ON-state Capacitance(Typ) | 13 пФ |
| Количество каналов | 1 |
| OFF-state leakage current(Max) | 0.005 мкА |
| ON-state leakage current(Max) | 0.01 мкА |
| Package Group | SOT-23 |
| Package Size: mm2:W x L | 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) PKG |
| Rating | Catalog |
| Ron(Max) | 20 Ohms |
| Ron(Typ) | 5 Ohms |
| Supply Current(Max) | 0.5 uA |
| Supply Current(Typ) | 0.01 uA |
| Supply Range | 5.5 Max |
| VIH(Min) | 2 В |
| VIL(Max) | 0.8 В |
| Vdd(Max) | 5.5 В |
| Vdd(Min) | 2.7 В |
| Vss(Max) | N/A В |
| Vss(Min) | N/A В |
- Preventing Excess Power Consumption on Analog SwitchesPDF, 238 Кб, Файл опубликован: 3 июл 2008
Analog switches are extensively used for switching audio signals in battery-powered applications, such as mobile phones. In any cases, the switch is powered directly from the battery, but it receives control signals from a lower voltage processor GPIO. For most analog switches, this application condition leads to an excess supply current draw that catches system designers by surprise. This applica
Серия: TS5A4596 (4)
- TS5A4596DBVR TS5A4596DBVRG4 TS5A4596DCKR TS5A4596DCKRG4
- Semiconductors > Switches and Multiplexers > Analog Switches/Muxes
