Datasheet Texas Instruments MSP430FR2032IG48R — Даташит
СерияMSP430FR2032
МодельMSP430FR2032IG48R
MSP430FR203x Микроконтроллеры смешанных сигналов 48-TSSOP от -40 до 85
MSP430FR203x Mixed-Signal Microcontrollers datasheet
PDF, 1.7 Мб, Версия: B, Файл опубликован: 14 авг 2015
Pin48
Package TypeDGG
Industry STD TermTSSOP
Package QTY2000
МаркировкаFR2032
Width (мм)6.1
Length (мм)12.5
Thickness (мм)1.15
Pitch (мм).5
Max Height (мм)1.2
ADCADC10 - 10ch
AESN/A
Active Power126 uA/MHz
Additional FeaturesReal-Time Clock,Watchdog,Temp Sensor,Brown Out Reset
BSLUART
CPUMSP430
Featuredfr2
Тактовая частота16 МГц
GPIO Pins60
I2C1
Max VCC3.6
Min VCC1.8
MultiplierN/A
Non-volatile Memory8 KB
Package GroupTSSOP
Package Size: mm2:W x L48TSSOP: 101 mm2: 8.1 x 12.5(TSSOP) PKG
RAM1 KB
SPI2
Security EnablerCryptographic acceleration,Debug security,Physical security,Secure FW and SW update,Software IP protection
Special I/ON/A
Standby Power1.31 LPM3-uA
Timers - 16-bit2
UART1
Wakeup Time10 us
  • Evaluation Modules & Boards: MSP-FET430U64D
    Target development board (64-pin) and MSP-FET programmer bundle for MSP430FR2x/4x MCUs
  • Evaluation Modules & Boards: MSP-EXP430FR4133
    MSP430FR4133 LaunchPad Development Kit
  • Evaluation Modules & Boards: MSP-TS430PM64D
    Target Development Board – 64 pins – for MSP430FR2x/4x MCUs
  • Daughter Cards: BOOST-IR
    Infrared (IR) BoosterPack Plug-in Module
    MSP EnergyTrace Technology
  • Migrating from the MSP430F4xx to Family to the MSP430FR4xx Family
    PDF, 194 Кб, Файл опубликован: 3 окт 2014
    This application report enables easy migration from MSP430F4xx flash-based MCUs to the MSP430FR4xx/FR2xx family of FRAM-based MCUs. It covers programming, system, and peripheral considerations when migrating firmware. The intent is to highlight key differences between the two families. For more information on the use of the MSP430FR4xx/FR2xx devices, see the MSP430FR4xx and MSP430FR2xx Family User
  • Infrared Remote Control Implementation With MSP430FR4xx (Rev. B)
    PDF, 329 Кб, Версия: B, Файл опубликован: 30 июн 2015
    This application report provides an insight into several of the most frequently used infrared protocols and especially their flexible implementation using the TI MSP430FR4xx series of low-power microcontrollers.The MSP430FR4xx microcontrollers are primarily targeted at remote control application that are equipped with infrared modulation function and an LCD display. The infrared modulation combi
  • VLO Calibration on the MSP430FR4xx and MSP430FR2xx Family (Rev. A)
    PDF, 78 Кб, Версия: A, Файл опубликован: 19 фев 2016
    MSP430FR4xx and MSP430FR2xx (FR4xx/FR2xx) family microcontrollers (MCUs) provide various clock sources, including some high-speed high-accuracy clocks and some low-power low-system-cost clocks. Users can select the best balance of performance, power consumption, and system cost. The on-chip very low-frequency oscillator (VLO) is a clock source with 10-kHz typical frequency included in FR4xx/FR2xx
  • MSP430 FRAM Technology – How To and Best Practices
    PDF, 326 Кб, Файл опубликован: 23 июн 2014
    FRAM is a non-volatile memory technology that behaves similar to SRAM while enabling a whole host of new applications, but also changing the way firmware should be designed. This application report outlines the how to and best practices of using FRAM technology in MSP430 from an embedded software development perspective. It discusses how to implement a memory layout according to application-specif
  • MSP430 FRAM Quality and Reliability (Rev. A)
    PDF, 295 Кб, Версия: A, Файл опубликован: 1 май 2014
    FRAM is a nonvolatile embedded memory technology and is known for its ability to be ultra-low power while being the most flexible and easy-to-use universal memory solution available today. This application report is intended to give new FRAM users and those migrating from flash-based applications knowledge on how FRAM meets key quality and reliability requirements such as data retention and endura
  • Migrating From MSP430 F2xx and G2xx Families to MSP430 FR4xx and FR2xx Family (Rev. E)
    PDF, 237 Кб, Версия: E, Файл опубликован: 4 май 2018
    This application report helps to ease the migration from MSP430F2xx flash-based MCUs to the MSP430FR4xx and MSP430FR2xx family of FRAM-based MCUs. It discusses programming system hardware core architecture and peripheral considerations. The intent is to highlight key differences between the two families. For more information on the use of the MSP430FR4xx and MSP430FR2xx devices see the MSP430
  • General Oversampling of MSP ADCs for Higher Resolution (Rev. A)
    PDF, 551 Кб, Версия: A, Файл опубликован: 1 апр 2016
    Multiple MSP ultra-low-power microcontrollers offer analog-to-digital converters (ADCs) to convert physical quantities into digital numbers, a function that is widely used across numerous applications. There are times, however, when a customer design demands a higher resolution than the ADC of the selected MSP can offer. This application report, which is based on the previously-published Oversampl
  • Semiconductors > Microcontrollers (MCU) > MSP430 ultra-low-power MCUs > MSP430FRxx FRAM
На английском языке: Datasheet Texas Instruments MSP430FR2032IG48R
