Datasheet Texas Instruments ADC12D500RFIUT — Даташит
СерияADC12D500RF
МодельADC12D500RFIUT
12-разрядный аналого-цифровой преобразователь (АЦП) с радиочастотной дискретизацией, двойной 500 MSPS или одиночный 1,0 GSPS 292-BGA от -40 до 85
ADC12D800/500RF 12-Bit, 1.6/1.0 GSPS RF Sampling ADC datasheet
PDF, 2.0 Мб, Версия: E, Файл опубликован: 25 мар 2013
Pin292
Package TypeNXA
Industry STD TermBGA
JEDEC CodeS-PBGA-N
Package QTY40
CarrierJEDEC TRAY (10+1)
МаркировкаADC12D500RFIUT
Width (мм)27
Length (мм)27
Thickness (мм)2.38
Max Height (мм)2.4
# Input Channels2,1
Analog Input BW2700 МГц
АрхитектураFolding Interpolating
DNL(Max)0.4 +/-LSB
DNL(Typ)0.4 +/-LSB
ENOB9.7 Bits
INL(Max)2.5 +/-LSB
INL(Typ)2.5 +/-LSB
Input BufferYes
Input Range0.8 Vp-p
InterfaceParallel LVDS
Package GroupBGA
Package Size: mm2:W x L292BGA: 729 mm2: 27 x 27(BGA) PKG
Power Consumption(Typ)2020 mW
Reference ModeInt
Разрешение12 Bits
SFDR74.3 дБ
SINAD60 дБ
SNR60.4 дБ
Sample Rate(Max)500,1000 MSPS
RoHSSee ti.com
  • Evaluation Modules & Boards: ADC12D800RFRB
    12-Bit, Dual 800 MSPS or Single 1.6 GSPS A/D Converter Reference Board
  • Synchronizing the Giga-Sample ADCs Interfaced with Multiple FPGAs
    PDF, 943 Кб, Файл опубликован: 6 авг 2014
  • AN-2177 Using the LMH6554 as a ADC Driver (Rev. A)
    PDF, 1.7 Мб, Версия: A, Файл опубликован: 26 апр 2013
    This application report discusses the use of the Texas Instruments LMH6554 as an ADC driver.
  • From Sample Instant to Data Output: Understanding Latency in the GSPS ADC
    PDF, 392 Кб, Файл опубликован: 18 дек 2012
    For many applications which use ultra high-speed ADCs, latency can be a critical performance specification. For example, if the ADC is used in any kind of feedback loop, then the absolute latency is an important factor. For a MIMO system such as a phased array radar, the relative difference and variability in latency becomes important. This application note covers latency in the GSPS ADC products,
  • AN-2132 Synchronizing Multiple GSPS ADCs in a System: The AutoSync Feature (Rev. G)
    PDF, 169 Кб, Версия: G, Файл опубликован: 3 фев 2017
  • Maximizing SFDR Performance in the GSPS ADC: Spur Sources and Methods of Mitigat
    PDF, 720 Кб, Файл опубликован: 9 дек 2013
    The SFDR performance of an ADC is limited by the largest spur in the spectrum from DC to Fs / 2. These spurs can either be reduced or avoided entirely for maximum SFDR performance, based on the application. This reference design explores the reason behind spurs in the 10-bit and 12-bit GSPS ADCfamily. The specific products covered are: ADC12D1800RF, ADC12D1600RF, ADC12D1000RF, ADC12D800RF, ADC12
Серия: ADC12D500RF (2)
  • Semiconductors > Data Converters > Analog-to-Digital Converters (ADCs) > High Speed ADCs (>10MSPS)
На английском языке: Datasheet Texas Instruments ADC12D500RFIUT
