Datasheet Texas Instruments TPS61181RTET — Даташит
СерияTPS61181
МодельTPS61181RTET
Драйвер белого светодиода 1,5 А для ноутбуков 16-WQFN от -40 до 85
WLED DRIVER FOR NOTEBOOK DISPLAY. datasheet
PDF, 1.1 Мб, Версия: E, Файл опубликован: 11 апр 2013
Pin16
Package TypeRTE
Industry STD TermWQFN
JEDEC CodeS-PQFP-N
Package QTY250
CarrierSMALL T&R
МаркировкаCCH
Width (мм)3
Length (мм)3
Thickness (мм).75
Pitch (мм).5
Max Height (мм).8
Количество каналов6
Duty Cycle(Max)94 %
LED60
LED Current Per Channel25 мА
Package GroupWQFN
Package Size: mm2:W x L16WQFN: 9 mm2: 3 x 3(WQFN) PKG
Peak Efficiency90 %
Shutdown Current(Typ)16 uA
Special FeaturesLoad Disconnect During Shutdown
Switching Frequency(Max)1000 kHz
TopologyBoost
ТипInductive
Vin(Max)24 В
Vin(Min)5 В
Vout(Max)39 В
Vout(Min)5 В
  • Evaluation Modules & Boards: TPS61181EVM-259
    TPS61181EVM-259 Evaluation Module
  • Evaluation Modules & Boards: WLEDEVM-260
    WLEDEVM-260 Evaluation Module
  • Evaluation Modules & Boards: SN65DSI85Q1-EVM
    Dual-Channel MIPIВ® DSI to Dual-Link FlatLinkВ™ LVDS Bridge Evaluation Module
  • Evaluation Modules & Boards: SN65DSI83Q1-EVM
    MIPIВ® DSI to FlatLinkВ™ LVDS Bridge Evaluation Module
  • Analog Dimming with the TPS61181
    PDF, 118 Кб, Файл опубликован: 8 ноя 2011
  • TPS61181 One-Cell Battery Application for Tablet PC Backlight
    PDF, 63 Кб, Файл опубликован: 9 сен 2010
    The TPS61181 is an ideal LED driver IC for medium form factor LCD backlighting. This device has a built-in, high-efficiency boost regulator with integrated 1.5-A/40-V power MOSFET. It provides six, current-sink regulators of 25 mA. The device can support up to 60 white LEDs. In addition, the boost output automatically adjusts its voltage to total LEDs forward voltage to optimize the whole solution
  • Extending the Input Voltage Range of the TPS6116x/8x/9x WLED Drivers
    PDF, 124 Кб, Файл опубликован: 12 авг 2009
    The TPS6116x, TPS6118x and TPS6119x WLED driver and TPS6117x boost converter integrated circuits (IC) can operate with different input voltages, one powering the IC itself and the other powering the boost power stage. This application report explains various options on how to use the WLED drivers with split power rails. This allows these LED drivers to be used in applications where the available
  • Semiconductors > Power Management > LED Driver > Backlight LED Driver
На английском языке: Datasheet Texas Instruments TPS61181RTET
