Datasheet Texas Instruments SN74LVT125QDRQ1 — Даташит
СерияSN74LVT125-Q1
МодельSN74LVT125QDRQ1
Автомобильный каталог Буферы с четырьмя шинами ABT, 3,3 В, с выходами с 3 состояниями, 14-SOIC, от -40 до 125
3.3-V ABT Quadruple Bus Buffer With 3-State Outputs datasheet
PDF, 793 Кб, Версия: B, Файл опубликован: 9 апр 2008
Микросхема Логический контроллер, Automotive Catalog 3.3V ABT Quadruple Bus Buffers With 3-State Outputs 14-SOIC -40℃ to 125℃
SN74LVT125QDRQ1
32 ₽
SN74LVT125QDRQ1
38 ₽
Рутоника
SN74LVT125QDRQ1
61 ₽
Hi-Tech Circuit Group
SN74LVT125QDRQ1
Pin14
Package TypeD
Package QTY2500
МаркировкаLVT125Q
Width (мм)3.91
Length (мм)8.65
Thickness (мм)1.58
Max Height (мм)1.75
Bits4
F @ Nom Voltage(Max)100 Mhz
ICC @ Nom Voltage(Max)0.007 мА
Output Drive (IOL/IOH)(Max)-32/32 мА
RatingAutomotive
Schmitt TriggerNo
Technology FamilyLVT
VCC(Max)3.6 В
VCC(Min)2.7 В
Voltage(Nom)3.3 В
tpd @ Nom Voltage(Max)4.2 нс
  • LVT Family Characteristics (Rev. A)
    PDF, 98 Кб, Версия: A, Файл опубликован: 1 мар 1998
    To address the need for a complete low-voltage interface solution, Texas Instruments has developed a new generation of logic devices capable of mixed-mode operation. The LVT series relies on a state-of-the-art submicron BiCMOS process to provide up to a 90% reduction in static power dissipation over ABT. LVT devices solve the system need for a transparent seam between the low-voltage and 5-V secti
  • LVT-to-LVTH Conversion
    PDF, 84 Кб, Файл опубликован: 8 дек 1998
    Original LVT devices that have bus hold have been redesigned to add the High-Impedance State During Power Up and Power Down feature. Additional devices with and without bus hold have been added to the LVT product line. Design guidelines and issues related to the bus-hold features, switching characteristics, and timing requirements are discussed.
На английском языке: Datasheet Texas Instruments SN74LVT125QDRQ1
Публикации по теме
