Datasheet Texas Instruments SN74LVC1G123DCTR — Даташит
СерияSN74LVC1G123
МодельSN74LVC1G123DCTR
Моностабильный мультивибратор с одним перезапуском и входами триггера Шмитта 8-SM8 от -40 до 125
SN74LVC1G123 Single Retriggerable Monostable Multivibrator With Schmitt-Trigger Inputs datasheet
PDF, 1.1 Мб, Версия: D, Файл опубликован: 22 июн 2015
Pin888
Package TypeDCTDCTDCT
Industry STD TermSSOPSSOPSSOP
Package QTY300030003000
CarrierLARGE T&RLARGE T&RLARGE T&R
МаркировкаRC23Z
Width (мм)2.82.82.8
Length (мм)2.952.952.95
Thickness (мм)1.291.291.29
Pitch (мм).65.65.65
Max Height (мм)1.31.31.3
3-State OutputNo
Bits1
F @ Nom Voltage(Max)150 Mhz
Gate TypeMULTIVIBRATOR
ICC @ Nom Voltage(Max)0.02 мА
LogicTrue
Output Drive (IOL/IOH)(Max)32/-32 мА
Package GroupSM8
Package Size: mm2:W x L8SM8: 12 mm2: 4 x 2.95(SM8) PKG
Schmitt TriggerYes
Special FeaturesIoff,down translation to Vcc,low power
Sub-FamilyMonostable Multivibrator
Technology FamilyLVC
VCC(Max)5.5 В
VCC(Min)1.65 В
Voltage(Nom)1.8,2.5,3.3,5 В
tpd @ Nom Voltage(Max)34,11,8,5.5 нс
  • Designing with the SN74LVC1G123 Monostable Multivibrator
    PDF, 158 Кб, Файл опубликован: 14 июл 2015
  • LVC Characterization Information
    PDF, 114 Кб, Файл опубликован: 1 дек 1996
    This document provides characterization information about low-voltage logic (LVL) that operates from a 3.3-V power supply. It addresses the issues of interfacing to 5-V logic ac performance power considerations input and output characteristics and signal integrity for this family of devices.
  • Use of the CMOS Unbuffered Inverter in Oscillator Circuits
    PDF, 796 Кб, Файл опубликован: 6 ноя 2003
    CMOS devices have a high input impedance high gain and high bandwidth. These characteristics are similar to ideal amplifier characteristics and hence a CMOS buffer or inverter can be used in an oscillator circuit in conjunction with other passive components. Now CMOS oscillator circuits are widely used in high-speed applications because they are economical easy to use and take significantly
  • Semiconductors > Logic > Little Logic
На английском языке: Datasheet Texas Instruments SN74LVC1G123DCTR
