Линейка продуктов KEEN SIDE
Datasheet Texas Instruments ADS8342IBPFBT — Даташит
СерияADS8342
МодельADS8342IBPFBT
16-разрядный АЦП с параллельным выходом, 250 kSPS, 4 истинно биполярных канала 48-TQFP от -40 до 85
ADS8342: 16-Bit, 250kSPS, 4-Channel, Parallel Output Analog-to-Digital Converter datasheet
PDF, 1.5 Мб, Файл опубликован: 6 фев 2003
Pin4848
Package TypePFBPFB
Industry STD TermTQFPTQFP
JEDEC CodeS-PQFP-GS-PQFP-G
Package QTY250250
CarrierSMALL T&RSMALL T&R
МаркировкаBADS8342I
Width (мм)77
Length (мм)77
Thickness (мм)11
Pitch (мм).5.5
Max Height (мм)1.21.2
# Input Channels4
Analog Voltage AVDD(Max)5.25 В
Analog Voltage AVDD(Min)-5.25 В
АрхитектураSAR
Digital Supply(Max)5.5 В
Digital Supply(Min)2.7 В
INL(Max)4 +/-LSB
Input Range(Max)2.5 В
Input Range(Min)-2.5 В
Тип входаPseudo-Differential,Single-Ended
Integrated FeaturesN/A
InterfaceParallel
Package GroupTQFP
Package Size: mm2:W x L48TQFP: 81 mm2: 9 x 9(TQFP) PKG
Power Consumption(Typ)208 mW
Reference ModeExt
Разрешение16 Bits
SINAD84.6 дБ
SNR86 дБ
Sample Rate (max)250kSPS SPS
Sample Rate(Max)0.25 MSPS
THD(Typ)-89 дБ
  • Evaluation Modules & Boards: ADS8342EVM
    ADS8342 Evaluation Module
  • ADS8342 ADC SAR Inputs
    PDF, 223 Кб, Файл опубликован: 6 янв 2005
    Successive approximation register analog-to-digital converters (SAR ADCs) present a challenging load to the circuitry that drives the analog inputs. Specifications in data sheets may mislead the user into thinking that analog inputs, for example, are static, when in fact they create a highly dynamic load that requires specially designed buffer circuitry. This article looks at the architecture of
  • Controlling the ADS8342 with TMS320 Series DSP's
    PDF, 109 Кб, Файл опубликован: 22 сен 2003
    The ADS8342 16-bit, bipolar input, parallel output analog-to-digital converter has a number of features that allow for an easy interface to many of the TMS320? DSP family of digital signal processors from Texas Instruments. This application note focuses on configuring, sampling, and converting analog data presented to the ADS8342 ADC, with software examples using the TMS320C6711 and C5416 DSPs. Th
  • Determining Minimum Acquisition Times for SAR ADCs, part 1 (Rev. A)
    PDF, 227 Кб, Версия: A, Файл опубликован: 10 ноя 2010
    This application report analyzes a simple method for calculating minimum acquisition times for successive-approximation register analog-to-digital converters (SAR ADCs). The input structure of the ADC is examined along with the driving circuit. The voltage on the sampling capacitor is then determined for the case when a step function is applied to the input of the driving circuit. Three different
Серия: ADS8342 (3)
На английском языке: Datasheet Texas Instruments ADS8342IBPFBT
