Datasheet Texas Instruments AFE031AIRGZT — Даташит
СерияAFE031
МодельAFE031AIRGZT
Аналоговый интерфейс Powerline Communications 48-VQFN от -40 до 125
Powerline Communications Analog Front-End datasheet
PDF, 1.2 Мб, Версия: D, Файл опубликован: 18 май 2012
Pin48
Package TypeRGZ
Industry STD TermVQFN
JEDEC CodeS-PQFP-N
Package QTY250
CarrierSMALL T&R
МаркировкаAFE031AI
Width (мм)7
Length (мм)7
Thickness (мм).9
Pitch (мм).5
Max Height (мм)1
Additional FeaturesShutdown,Adj Current Limit
АрхитектураFET
GBW(Typ)0.67 МГц
Iq per channel(Max)60.3 мА
Iq per channel(Typ)49 мА
Количество каналов1
Output Current(Typ)1500 мА
Package GroupVQFN
Package Size: mm2:W x L48VQFN: 49 mm2: 7 x 7(VQFN) PKG
Rail-to-RailNo
Slew Rate(Typ)19 V/us
Total Supply Voltage(Max)26 +5V=5, +/-5V=10
Total Supply Voltage(Min)7 +5V=5, +/-5V=10
  • Evaluation Modules & Boards: TMDSPLCKITV4-CEN
    Power Line Communications Kit for CENELEC Frequency Band
  • Evaluation Modules & Boards: TMDSDC3359
    Data Concentrator Evaluation Module
  • Evaluation Modules & Boards: 24VDCPLCEVM
    DC Power Line Communication (PLC) Reference Design
  • AFE Design for a Narrowband Power-Line Communications Modem Using the AFE031 (Rev. A)
    PDF, 498 Кб, Версия: A, Файл опубликован: 3 ноя 2011
    Designing an analog front-end (AFE) for a power-line modem can be very challenging. Using the AFE031 simplifies this task and allows the designer to focus on the critical elements of the design, such as the line coupling interface, circuit protection, and printed circuit board (PCB) thermal design. This report uses the AFE031 to demonstrate an effective method of designing and testing an AFE for a
  • Interfacing the C2000 with an AFE03x: B-FSK Example
    PDF, 2.7 Мб, Файл опубликован: 30 июн 2017
    This application report provides information on how to interface a C2000 device with an AFE031, and send data over a wired coupled interface using frequency shift keying. A demonstration of transmitting FSK information is discussed with tone frequencies in the 130-145 kHz range.
Серия: AFE031 (2)
  • Semiconductors > Amplifiers > Operational Amplifiers (Op Amps) > Power Op Amps
На английском языке: Datasheet Texas Instruments AFE031AIRGZT
