Datasheet Texas Instruments TPS76427DBVR — Даташит
СерияTPS764
МодельTPS76427DBVR
Малошумящий линейный стабилизатор с низким Iq, 150 мА и малым падением напряжения 5-SOT-23
Low-Power Low-Noise 150-mA Low-Dropout Linear Regulator datasheet
PDF, 433 Кб, Версия: B, Файл опубликован: 4 май 2001
Чип стабилизации напряжения, Single Channel LDO Single Output LDO, 150mA, Fixed(2.7V), Low Noise, Low Quiescent Current LDO Regulator Pos 2.7V 0.15A...
TPS76427DBVR
36 ₽
TPS76427DBVR
36 ₽
TPS76427DBVR
84 ₽
TPS76427DBVR
Pin5
Package TypeDBV
Industry STD TermSOT-23
Package QTY3000
МаркировкаPBKI
Width (мм)1.6
Length (мм)2.9
Thickness (мм)1.2
Pitch (мм).95
Max Height (мм)1.45
Точность3 %
Fixed Output Options2.5,2.7,2.8,3,3.3 В
Iout(Max)0.15 A
Iq(Typ)0.08 мА
Noise50 uVrms
Output OptionsFixed Output
PSRR @ 100KHz32 дБ
Package GroupSOT-23
Package Size: mm2:W x L5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) PKG
Regulated Outputs1
Special FeaturesEnable
Thermal Resistance ОёJA180 В°C/W
Vdo(Typ)300 мВ
Vin(Max)10 В
Vin(Min)2.7 В
Vout(Max)3.3 В
Vout(Min)2.5 В
  • Evaluation Modules & Boards: DEM-SOT23LDO
    DEM-SOT23LDO Compatible With Most Positive-Output LDO Regulators in 5- or 6-Lead SOT23 (DBV) Package
  • Technical Review of Low Dropout Voltage Regulator Operation And Performance
    PDF, 284 Кб, Файл опубликован: 30 авг 1999
    This application report provides a technical review of low dropout (LDO) voltage regulators and describes fundamental concepts including dropout voltage quiescent current and topologies. The report also includes detailed discussions of load/line regulation efficiency frequency response range of stable ESR and accuracy of LDO voltage regulators.
  • Fundamental Theory of PMOS LDO Voltage Regulators
    PDF, 66 Кб, Файл опубликован: 7 май 1999
    This report presents a fundamental understanding on the theory of low-dropout voltage regulators using a PMOS FET as the pass element to adjust the output current to the load requirements.
На английском языке: Datasheet Texas Instruments TPS76427DBVR
