Datasheet Texas Instruments TL594CNSRG4 — Даташит
| Серия | TL594 |
| Модель | TL594CNSRG4 |
Цепь управления широтно-импульсной модуляцией (ШИМ) 16-SO от 0 до 70
TL594 Pulse-Width-Modulation Control Circuit datasheet
PDF, 1.4 Мб, Версия: I, Файл опубликован: 30 сен 2016
Купить TL594CNSRG4 на РадиоЛоцман.Цены — от 8.93 до 151 ₽10 предложений от 10 поставщиков Чип стабилизации напряжения, Voltage Mode PWM Controller 40V 200mA 300kHz 16Pin SOP T/R | |||
| TL594CNSRG4 Texas Instruments | 32 ₽ | ||
| TL594CNSRG4 Texas Instruments | 151 ₽ | ||
| TL594CNSRG4 | по запросу | ||
| TL594CNSRG4 Texas Instruments | по запросу | ||
| Pin | 16 |
| Package Type | NS |
| Industry STD Term | SOP |
| JEDEC Code | R-PDSO-G |
| Package QTY | 2000 |
| Carrier | LARGE T&R |
| Маркировка | TL594 |
| Width (мм) | 5.3 |
| Length (мм) | 10.3 |
| Thickness (мм) | 1.95 |
| Pitch (мм) | 1.27 |
| Max Height (мм) | 2 |
| Mechanical Data | Скачать |
| Control Method | Voltage |
| Duty Cycle(Max) | 45 % |
| Frequency(Max) | 300 kHz |
| Frequency(Min) | 1 kHz |
| Gate Drive(Typ) | 0.2 A |
| Рабочий диапазон температур | от -40 до 85,0 до 70 C |
| Package Group | SO |
| Rating | Catalog |
| Special Features | Adjustable Switching Frequency,Error Amplifier,Multi-topology |
| Topology | Boost,Buck,Flyback,Forward,Full-Bridge,Half-Bridge,Push-Pull |
| UVLO Thresholds On/Off | 6.1/6 В |
| Vin(Max) | 38 В |
| Vin(Min) | -0.3 В |
- Understanding Buck Power Stages In Switchmode Power SuppliesPDF, 173 Кб, Файл опубликован: 4 мар 1999
A switching power supply consists of the power stage and the control circuit. The power stage performs the basic power conversion from the input voltage to the output voltage and includes switches and the output filter. This report addresses the buck power stage only and does not cover control circuits. Detailed steady-state and small-signal analysis of the buck power stage operating in continuous - Understanding Boost Power Stages In Switchmode Power SuppliesPDF, 149 Кб, Файл опубликован: 4 мар 1999
A switching power supply consists of the power stage and the control circuit. The power stage performs the basic power conversion from the input voltage to the output voltage and includes switches and the output filter. This report addresses the boost power stage only and does not cover control circuits. The report includes detailed steady-stage and small-signal analysis of the boost power stage o - Understanding Buck-Boost Power Stages in Switchmode Power Supplies (Rev. A)PDF, 363 Кб, Версия: A, Файл опубликован: 28 май 2002
Серия: TL594 (23)
- Semiconductors > Power Management > Offline and Isolated DC/DC Controllers and Converters > PWM and Resonant Controller
