Datasheet Texas Instruments SN74CBTS6800PWR — Даташит
СерияSN74CBTS6800
МодельSN74CBTS6800PWR
10-битный переключатель шины на полевых транзисторах с предварительно заряженными выходами и ограничением на диоде Шоттки 24-TSSOP от -40 до 85
10-Bit FET Bus Switch With Precharged Outputs And Schottky Diode Clamping datasheet
PDF, 730 Кб, Версия: C, Файл опубликован: 20 окт 2000
Pin24
Package TypePW
Industry STD TermTSSOP
Package QTY2000
МаркировкаCS6800
Width (мм)4.4
Length (мм)7.8
Thickness (мм)1
Max Height (мм)1.2
Additional FeaturesPre-charged signal path, Schottky clamp diode to prevent undershoot
Полоса частот200 МГц
Configuration1:1 SPST
Input/Ouput Voltage(Max)5.5 В
Input/Output Continuous Current(Max)128 мА
Input/Output OFF-state Capacitance(Typ)4.5 пФ
Количество каналов10
Package GroupTSSOP
Package Size: mm2:W x L24TSSOP: 50 mm2: 6.4 x 7.8(TSSOP) PKG
Ron(Max)20 Ohms
Ron(Typ)3 Ohms
Supply Current(Max)2500 uA
Supply Current(Typ)2.5 uA
Supply Range5.5 Max
VIH(Min)2 В
VIL(Max)0.8 В
Vdd(Max)5.5 В
Vdd(Min)4 В
Vss(Max)N/A В
Vss(Min)N/A В
  • FET Switches in Docking Stations
    PDF, 92 Кб, Файл опубликован: 23 июл 2003
    Docking stations for portable electronics require the capability to connect a system with a live-running bus to a disabled or powered-down system. This hot-docking event must not cause any electrical damage, electrical signal glitches, or data corruption. This application report explains the use of TI FET bus-switch products with precharge to accomplish this connection.
  • Flexible Voltage-Level Translation With CBT Family Devices
    PDF, 40 Кб, Файл опубликован: 20 июл 1999
    Voltage translation between buses with incompatible logic levels can be accomplished using Texas Instruments (TI) translation-voltage clamps (TVC) or standard crossbar technology (CBT) devices. CBT devices in this application offer flexibility in designs, protection of circuits that are sensitive to high-state voltage-level overshoots, and cost efficiency.
  • 5-V To 3.3-V Translation With the SN74CBTD3384 (Rev. B)
    PDF, 35 Кб, Версия: B, Файл опубликован: 1 мар 1997
    The emergence of low-voltage technology required existing 5-V systems to interact with 3.3-V systems. Compatibility issues of mixed-mode operation created the need for 5-V to 3.3-V translation. Buffers and transceivers serve as effective translators. While providing additional drive, these devices also add propagation delay and require directional control. In cases where additional drive is not
  • 3.3-V to 2.5-V Translation with Texas Instruments Crossbar Technology (Rev. A)
    PDF, 32 Кб, Версия: A, Файл опубликован: 3 апр 1998
  • VOLTAGE LEVEL TRANSLATION (SL) - Family
    PDF, 111 Кб, Файл опубликован: 21 сен 2011
Серия: SN74CBTS6800 (2)
На английском языке: Datasheet Texas Instruments SN74CBTS6800PWR
