Datasheet Texas Instruments CD54HC4051F — Даташит
СерияCD54HC4051
МодельCD54HC4051F
Высокоскоростные аналоговые мультиплексоры/демультиплексоры КМОП-логики 16-CDIP от -55 до 125
CDx4HC405x, CDx4HCT405x High-Speed CMOS Logic Analog Multiplexers and Demultiplexers datasheet
PDF, 1.5 Мб, Версия: L, Файл опубликован: 6 фев 2017
Микросхема Мультиплексор, Analog Multiplexer Single 8:1 16Pin CDIP Tube
CD54HC4051F3A
794 ₽
CD54HC4051F3A-PULLS
727GS
CD54HC4051F
CD54HC4051F3A
Pin16
Package TypeJ
Industry STD TermCDIP
JEDEC CodeR-GDIP-T
Package QTY1
МаркировкаCD54HC4051F
Width (мм)6.92
Length (мм)19.56
Thickness (мм)4.57
Pitch (мм)2.54
Max Height (мм)5.08
Additional FeaturesLow Power,Low Crosstalk,Break-before-make
Bandwidth(Max)180 МГц
Package GroupCDIP
RatingMilitary
Ron(Max)130 Ohms
Ron(Typ)45 Ohms
Schmitt TriggerNo
Technology FamilyHC
VCC(Max)6 В
VCC(Min)2 В
RoHSSee ti.com
  • Selecting the Right Texas Instruments Signal Switch
    PDF, 769 Кб, Файл опубликован: 7 сен 2001
    Texas Instruments offers a wide variety of electronic switches (digital analog bilateral bilateral analog) in a variety of families including CBT CBTLV HC LV and LVC. Depending on the application the right solution may be an analog switch that passes digital signals or vice versa. This application report summarizes the various switching technologies and provides considerations for choosi
Серия: CD54HC4051 (2)
  • Semiconductors > Space & High Reliability > Logic Products > Switches and Multiplexer > Multiplexers/Demultiplexers (Mux/Demux)
На английском языке: Datasheet Texas Instruments CD54HC4051F
