Datasheet Texas Instruments TPS61031PWPRG4 — Даташит
СерияTPS61031
МодельTPS61031PWPRG4
Выход 3,3 В, 1 А, повышающий преобразователь с КПД 96 %, Iq 20 мкА в TSSOP-16 16-HTSSOP от -40 до 85
TPS6103x 96% Efficient Synchronous Boost Converter With 4A Switch datasheet
PDF, 1.4 Мб, Версия: G, Файл опубликован: 10 мар 2015
Pin16
Package TypePWP
Industry STD TermHTSSOP
Package QTY2000
МаркировкаPS61031
Width (мм)4.4
Length (мм)5
Thickness (мм)1
Max Height (мм)1.2
Duty Cycle(Max)100 %
Iq(Typ)0.02 мА
Package GroupHTSSOP
Regulated Outputs1
Special FeaturesEnable,Frequency Synchronization,Light Load Efficiency,Load Disconnect,Power Good
Switch Current Limit(Min)3.6 A
Switch Current Limit(Typ)4 A
Switching Frequency(Max)700 kHz
Switching Frequency(Min)500 kHz
ТипConverter
Vin(Max)5.5 В
Vin(Min)1.8 В
Vout(Max)3.3 В
Vout(Min)3.3 В
  • Evaluation Modules & Boards: TPS61032EVM-208
    TPS61032 Evaluation Module
  • Evaluation Modules & Boards: TPS61030EVM-029
    TPS61030 Evaluation Module (QFN Package)
  • Evaluation Modules & Boards: TPS61030EVM-208
  • Evaluation Modules & Boards: TPS61031EVM-208
    TPS61031 Evaluation Module
  • Five Steps to a Good PCB Layout of the Boost Converter
    PDF, 701 Кб, Файл опубликован: 3 май 2016
  • Minimizing Ringing at the Switch Node of a Boost Converter
    PDF, 201 Кб, Файл опубликован: 15 сен 2006
    The application report explains how to use proper board layout and/or a snubber to reduce high-frequency ringing at the switch node of a boost converter.
  • Basic Calculation of a Boost Converter's Power Stage (Rev. C)
    PDF, 186 Кб, Версия: C, Файл опубликован: 8 янв 2014
    This application note gives the equations to calculate the power stage of a boost converter built with an IC with integrated switch and operating in continuous conduction mode. It is not intended to give details on the functionality of a boost converter (see Reference 1) or how to compensate a converter. See the references at the end of this document if more detail is needed.
  • PowerPAD Thermally Enhanced Package (Rev. H)
    PDF, 983 Кб, Версия: H, Файл опубликован: 6 июл 2018
  • QFN and SON PCB Attachment (Rev. B)
    PDF, 821 Кб, Версия: B, Файл опубликован: 24 авг 2018
Серия: TPS61031 (5)
  • Semiconductors > Power Management > Non-isolated DC/DC Switching Regulator > Step-Up (Boost) > Boost Converter (Integrated Switch)
На английском языке: Datasheet Texas Instruments TPS61031PWPRG4
