Datasheet Texas Instruments THS1206QDAR — Даташит
СерияTHS1206
МодельTHS1206QDAR
12-разрядный четырехканальный АЦП, 6 MSPS.
THS1206: 12-Bit, 6 MSPS, Simultaneous Sampling Analog-to-Digital Converter datasheet
PDF, 1.1 Мб, Версия: H, Файл опубликован: 27 июн 2003
Микросхема Преобразователь AD, Analog to Digital Converters - ADC 12Bit, 6MSPS ADC Quad Ch. (Config.), DSP/uP IF, Integ. 16x FIFO, Channel...
Рутоника
THS1206QDAR
ТаймЧипс
THS1206QDAR
THS1206QDAR
727GS
THS1206QDAR
(Конфиг.), DSP/uP IF, Интегр. 16x FIFO, автоматическое сканирование каналов, малое энергопотребление 32-TSSOP от -40 до 125
Pin32
Package TypeDA
Industry STD TermTSSOP
Width (мм)6.2
Length (мм)11
Thickness (мм)1.15
Max Height (мм)1.2
# Input Channels4
Analog Voltage AVDD(Max)(V)5.25
Analog Voltage AVDD(Min)(V)4.75
Approx. Price (US$)10.20 | 1ku
АрхитектураPipeline
Digital Supply(Max)(V)5.25
Digital Supply(Min)(V)3
INL(Max)(+/-LSB)1.5
Input Range(Max)(V)4
Input Range(Min)(V)1.4
Тип входаDifferential
Single-Ended
Integrated FeaturesN/A
InterfaceParallel
Multi-Channel ConfigurationSimultaneous Sampling
Operating Temperature Range(C)-40 to 125
-40 to 85
0 to 70
Package GroupTSSOP
Package Size: mm2:W x L (PKG)32TSSOP: 89 mm2: 8.1 x 11(TSSOP)
Power Consumption(Typ)(mW)186
Reference ModeExt
Int
Resolution(Bits)12
SINAD(dB)65
SNR(dB)69
Sample Rate (max)(SPS)6MSPS
THD(Typ)(dB)-70
RoHSНе совместим
  • Evaluation Modules & Boards: THS1206M-EVM
    THS1206M Evaluation Module
  • Synchronizing non-FIFO variations of the THS1206
    PDF, 219 Кб, Файл опубликован: 28 фев 2005
  • Designing with the THS1206 High-Speed Data Converter
    PDF, 167 Кб, Файл опубликован: 4 апр 2000
    This application report is intended as a guide in the use of the digital and analog portions of the THS1206 A/D converter. On the digital portion, it discusses the main timing features to explain the requirements for initialization and operation. Two interface examples are presented where the THS1206 is connected to digital signal processors TMS320C54x and TMS320C6201. On the analog portion, it of
  • Resetting Non-FIFO Variations of the 12-bit THS1206
    PDF, 38 Кб, Файл опубликован: 9 май 2002
    The THS1207 and THS1209 are non-FIFO variations of the THS1206. They require some special procedures for properly resetting and configuring the device. This application brief helps explain the necessary steps required to get reliable data from these 12-bit, two and four channel simultaneous sampling data converters.
  • Semiconductors > Data Converters > Analog to Digital Converter > Precision ADC (<=10MSPS)
На английском языке: Datasheet Texas Instruments THS1206QDAR
