Datasheet Texas Instruments TPS5420DRG4 — Даташит
СерияTPS5420
МодельTPS5420DRG4
Входное напряжение от 5,5 В до 36 В, 2 А, 500 кГц Понижающий преобразователь 8-SOIC от -40 до 125
2-A Wide Input Range Step-Down Converter datasheet
PDF, 1.1 Мб, Версия: E, Файл опубликован: 5 сен 2013
Package TypeD
Package QTY2500
МаркировкаTPS5420
Width (мм)3.91
Length (мм)4.9
Thickness (мм)1.58
Max Height (мм)1.75
Control ModeVoltage Mode
Duty Cycle(Max)87 %
Iout(Max)2 A
Iq(Typ)3 мА
Regulated Outputs1
Special FeaturesEnable
Switching Frequency(Max)500 kHz
Switching Frequency(Min)500 kHz
ТипConverter
Vin(Max)36 В
Vin(Min)5.5 В
Vout(Max)31 В
Vout(Min)1.23 В
  • Evaluation Modules & Boards: TPS5420EVM-175
    10V to 36Vin, 2A Step Down Converter Evaluation Module
  • Power-supply design for high-speed ADCs (Rev. A)
    PDF, 761 Кб, Версия: A, Файл опубликован: 18 май 2015
  • Output Ripple Voltage for Buck Switching Regulator (Rev. A)
    PDF, 2.4 Мб, Версия: A, Файл опубликован: 13 окт 2014
  • Using the TPS5430 As An Inverting Buck Boost Converter (Rev. A)
    PDF, 266 Кб, Версия: A, Файл опубликован: 15 авг 2007
    The wide input voltage range SWIFTв„ў dc/dc converters are used typically as step-down converters where the derived output is a positive voltage less than the input voltage source. In some cases, it may be required to generate a negative voltage from the input voltage source. In such instances, it is possible to configure the TPS5430/20/10 devices in an inverting buck-boost topology, where the outpu
  • Using TPS5410/20/30/31/50 w/Aluminum/Ceramic Output Capacitors (Rev. C)
    PDF, 392 Кб, Версия: C, Файл опубликован: 21 мар 2007
    As internally compensated devices, the wide input step-down SWIFTв„ў DC/DC converters, including TPS5410/5420/5430/5431/5450, have the advantages of less external part count and reduced design complexity, as well as limited output capacitor selection. By adding only two or three external components into the standard circuitry, these devices generally work well with aluminum/ceramic output capacitors
  • Q1 2010 Issue Analog Applications Journal
    PDF, 2.6 Мб, Файл опубликован: 29 янв 2010
Серия: TPS5420 (4)
На английском языке: Datasheet Texas Instruments TPS5420DRG4
