Datasheet Texas Instruments OPA1664AIPWR — Даташит
Серия | OPA1664 |
Модель | OPA1664AIPWR |
Звуковые операционные усилители Sound Plus с низким энергопотреблением, низким уровнем шума и искажений 14-TSSOP от -40 до 85
SoundPlus™ Low-Power, Low Noise & Distortion, Bipolar-Input AUDIO OP AMPS datasheet
PDF, 1.9 Мб, Файл опубликован: 20 дек 2011
Pin | 14 |
Package Type | PW |
Industry STD Term | TSSOP |
JEDEC Code | R-PDSO-G |
Package QTY | 2000 |
Carrier | LARGE T&R |
Маркировка | OPA1664 |
Width (мм) | 4.4 |
Length (мм) | 5 |
Thickness (мм) | 1 |
Pitch (мм) | .65 |
Max Height (мм) | 1.2 |
Mechanical Data | Скачать |
Additional Features | Burr-Brownв„ў Audio |
Архитектура | Bipolar |
CMRR(Min) | 86 дБ |
CMRR(Typ) | 100 дБ |
GBW(Typ) | 22 МГц |
Input Bias Current(Max) | 1200000 pA |
Iq per channel(Max) | 1.8 мА |
Iq per channel(Typ) | 1.5 мА |
Количество каналов | 4 |
Offset Drift(Typ) | 2 uV/C |
Output Current(Typ) | 40 мА |
Package Group | TSSOP |
Package Size: mm2:W x L | 14TSSOP: 32 mm2: 6.4 x 5(TSSOP) PKG |
Rail-to-Rail | No |
Rating | Catalog |
Slew Rate(Typ) | 17 V/us |
Total Supply Voltage(Max) | 36 +5V=5, +/-5V=10 |
Total Supply Voltage(Min) | 3 +5V=5, +/-5V=10 |
Vn at 1kHz(Typ) | 3.3 нВ/rtГц |
Vos (Offset Voltage @ 25C)(Max) | 1.5 мВ |
- OPA1662, OPA1664 EMIR Immunity PerformancePDF, 283 Кб, Файл опубликован: 21 дек 2012
- Compensate Transimpedance Amplifiers Intuitively (Rev. A)PDF, 69 Кб, Версия: A, Файл опубликован: 30 мар 2005
Transimpedance amplifiers are used to convert low-level photodiode currents to usable voltage signals. All too often, the amplifiers have to be empirically compensated to operate properly. The problem can be easily understood if one looks at all the elements involved. - Tuning in AmplifiersPDF, 44 Кб, Файл опубликован: 2 окт 2000
Have you ever had the experience of designing an analog gain block with an amplifier that is specified to be unity gain stable only to find that it is oscillating out of control in your circuit? Or have you ever replaced a stable voltage feedback amplifier with a current feedback amplifier to find that the current feedback amplifier immediately oscillates when placed in the amplifier socket? Oscil - Single-Supply Operation of Operational AmplifiersPDF, 77 Кб, Файл опубликован: 2 окт 2000
Operation of op amps from single supply voltages is useful when negative supply voltages are not available. Furthermore, certain applications using high voltage and high current op amps can derive important benefits from single supply operation. - Op Amp Performance AnalysisPDF, 76 Кб, Файл опубликован: 2 окт 2000
Серия: OPA1664 (4)
- OPA1664AID OPA1664AIDR OPA1664AIPW OPA1664AIPWR
