Datasheet Texas Instruments TS3A5018DRE4 — Даташит
СерияTS3A5018
МодельTS3A5018DRE4
Аналоговый переключатель Quad SPDT 10 Ом 16-SOIC от -40 до 85
TS3A5018 10-Ω Quad SPDT Analog Switch datasheet
PDF, 1.8 Мб, Версия: G, Файл опубликован: 26 мар 2015
Pin16
Package TypeD
Package QTY2500
МаркировкаTS3A5018
Width (мм)3.91
Length (мм)9.9
Thickness (мм)1.58
Max Height (мм)1.75
Полоса частот300 МГц
Bandwidth(Max)300 МГц
Configuration2:1 SPDT
ESD Charged Device Model1 kV
ESD HBM2 kV
Input/Ouput Voltage(Max)3.6 В
Input/Output Continuous Current(Max)64 мА
Input/Output OFF-state Capacitance(Typ)3 пФ
Input/Output ON-state Capacitance(Typ)16 пФ
Количество каналов4
OFF-state leakage current(Max)10 мкА
ON-state leakage current(Max)2 мкА
Ron(Max)22 Ohms
Ron(Typ)5.5 Ohms
Supply Current(Max)2 uA
Supply Current(Typ)0.7 uA
Supply Range3.6 Max
VIH(Min)1 В
VIL(Max)0.8 В
Vdd(Max)3.6 В
Vdd(Min)1.65 В
Vss(Max)N/A В
Vss(Min)N/A В
  • Evaluation Modules & Boards: MMWAVE-DEVPACK
    mmWave Development Pack (DevPack)
  • Preventing Excess Power Consumption on Analog Switches
    PDF, 238 Кб, Файл опубликован: 3 июл 2008
    Analog switches are extensively used for switching audio signals in battery-powered applications, such as mobile phones. In any cases, the switch is powered directly from the battery, but it receives control signals from a lower voltage processor GPIO. For most analog switches, this application condition leads to an excess supply current draw that catches system designers by surprise. This applica
На английском языке: Datasheet Texas Instruments TS3A5018DRE4
