Datasheet Texas Instruments UCC24636DBVT — Даташит
СерияUCC24636
МодельUCC24636DBVT
Контроллер синхронного выпрямителя со сверхнизким током в режиме ожидания 6-SOT-23 от -40 до 125
UCC24636 Synchronous Rectifier (SR) Controller With Ultra-Low Standby Current datasheet
PDF, 2.1 Мб, Версия: A, Файл опубликован: 11 мар 2016
Pin6
Package TypeDBV
Industry STD TermSOT-23
Package QTY250
CarrierSMALL T&R
МаркировкаU636
Width (мм)1.6
Length (мм)2.9
Thickness (мм)1.2
Pitch (мм).95
Max Height (мм)1.45
Frequency(Max)130 kHz
Package GroupSOT-23
Package Size: mm2:W x L6SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) PKG
Special FeaturesUSB Type-C Compatible
UVLO Thresholds On/Off4/3.6 В
  • Evaluation Modules & Boards: UCC24636EVM
    UCC24636 Synchronous Rectifier Daughter Board/Evaluation Module
  • Design UCC28704 With UCC24636 (PSR+SR)
    PDF, 137 Кб, Файл опубликован: 12 янв 2017
    Higher power conversion efficiency in a switch-mode power supply is usually obtained for use in a synchronous rectifier (SR) on a secondary-side controller. For example, to use the UCC24636, work with a primary-side regulated (PSR) controller such as the UCC28704. A primary-side regulated converter does not need an optocoupler to obtain the output voltage signal from the secondary-side controller
  • Agency requirements for stand-by power consumption w/ offline and PoL converters
    PDF, 160 Кб, Файл опубликован: 26 янв 2016
Серия: UCC24636 (2)
  • Semiconductors > Power Management > Offline and Isolated DC/DC Controllers and Converters > Synchronous Rectifier
На английском языке: Datasheet Texas Instruments UCC24636DBVT
