Datasheet Texas Instruments THS6032IGQER — Даташит
СерияTHS6032
МодельTHS6032IGQER
Драйвер линии центрального офиса ADSL с низким энергопотреблением 80-BGA MICROSTAR JUNIOR от -40 до 85
Low-Power ADSL Central-Office Line Driver datasheet
PDF, 1.2 Мб, Версия: F, Файл опубликован: 25 авг 2009
Pin80
Package TypeGQE
Industry STD TermBGA MICROSTAR JUNIOR
JEDEC CodeS-PBGA-N
Width (мм)5
Length (мм)5
Thickness (мм).74
Pitch (мм).5
Max Height (мм)1
2nd Harmonic(dBc)79
3rd Harmonic(dBc)68
@ MHz1
Acl, min spec gain(V/V)1
Additional FeaturesShutdown
Approx. Price (US$)5.65 | 1ku
АрхитектураCurrent FB
BW @ Acl(MHz)100
CMRR(Min)(dB)64
CMRR(Typ)(dB)72
GBW(Typ)(MHz)100
Input Bias Current(Max)(pA)9000000
Iq per channel(Max)(mA)10.8
Iq per channel(Typ)(mA)8.3
Number of Channels(#)2
Offset Drift(Typ)(uV/C)10
Operating Temperature Range(C)-40 to 85
0 to 70
Output Current(Typ)(mA)440
Package GroupHLQFP
SO PowerPAD
Package Size: mm2:W x L (PKG)32HLQFP: 81 mm2: 9 x 9(HLQFP)
20SO PowerPAD: 133 mm2: 10.405 x 12.825(SO PowerPAD)
Rail-to-RailNo
Slew Rate(Typ)(V/us)1200
Total Supply Voltage(Max)(+5V=5, +/-5V=10)32
Total Supply Voltage(Min)(+5V=5, +/-5V=10)10
Vn at Flatband(Typ)(nV/rtHz)2.4
Vos (Offset Voltage @ 25C)(Max)(mV)5
RoHSНе совместим
  • Active Output Impedance for ADSL Line Drivers
    PDF, 636 Кб, Файл опубликован: 26 ноя 2002
    Signal termination is very common in bidirectional communication systems. Termination allows for receiving signals while transmitting different signals at the same time. With the increasing popularity of asymmetrical digital subscriber lines (ADSL), the requirement for a low power line driver amplifier combined with line termination becomes a very difficult goal. This application note examines the
На английском языке: Datasheet Texas Instruments THS6032IGQER
