Datasheet Texas Instruments LMT84DCKR — Даташит
СерияLMT84
МодельLMT84DCKR
Датчик температуры с аналоговым выходом 1,5 В, 10 мкА в SC70 и TO-92 5-SC70 от -50 до 150
LMT84, LMT84-Q1 1.5-V, SC70/TO-92/TO-92S, Analog Temperature Sensors datasheet
PDF, 1.5 Мб, Версия: D, Файл опубликован: 23 июн 2017
39 предложений от 13 поставщиков
SENSOR ANALOG -50C-150C SC70-5. Temperature Sensor Analog, Local -50°C ~ 150°C 5.5mV/°C SC-70-5. Temperature Sensors - Analog and Digital Output
Зенер
Россия и страны ТС
LMT84DCKR
от 24 ₽
Xinhuo Future
LMT84DCKR
727GS
LMT84DCKR
LMT84DCKR
Pin5
Package TypeDCK
Industry STD TermSOT-SC70
Package QTY3000
МаркировкаBNA
Width (мм)1.25
Length (мм)2
Thickness (мм).9
Max Height (мм)1.1
InterfaceAnalog Output
Local Sensor Accuracy(Max)2.7 +/- C
Рабочий диапазон температурот -50 до 150 C
Package GroupTO-92
Package Size: mm2:W x L3TO-92: 13 mm2: 3.15 x 4(TO-92) PKG
Sensor Gain-5.5 mV/Deg C
Special FeaturesIndustry standard pinout
Supply Current(Max)8.1 uA
Supply Voltage(Max)5.5 В
Supply Voltage(Min)1.5 В
  • Evaluation Modules & Boards: LMT84-7EVM
    EVM for LMT84, LMT85, LMT86 and LMT87 Temperature Sensor
  • SC Temp Sensors Challenge Precision RTDs and Thermistors in Build Automation
    PDF, 247 Кб, Файл опубликован: 21 апр 2015
    Standalone semiconductor sensors have rarely been considered for implementation into sensor probes or assemblies due to their larger geometries. However, advances in process technology and design have led to new, tiny sensor structures with almost linear transfer functions.In order to provide system designers with this new low-cost alternative to precision temperature measurement, this appl
  • Semiconductors > Sensing Products > Temperature Sensors > Local Analog Temperature Sensors
На английском языке: Datasheet Texas Instruments LMT84DCKR
