Datasheet Texas Instruments UCC3819APW — Даташит
СерияUCC3819A
МодельUCC3819APW
Предварительный регулятор коэффициента мощности BiCMOS 16-TSSOP от 0 до 70
UCC2819A Power Factor Preregulator datasheet
PDF, 1.0 Мб, Файл опубликован: 9 сен 2003
21 предложений от 18 поставщиков
Интегральные микросхемы Микросхемы управления электропитанием - Коррекция коэффициента мощности
UCC3819APW
163 ₽
UCC3819APW
163 ₽
UCC3819APW
МосЧип
UCC3819APW
Pin16
Package TypePW
Industry STD TermTSSOP
Маркировка3819A
Width (мм)4.4
Length (мм)5
Thickness (мм)1
Max Height (мм)1.2
Approx. Price (US$)1.40 | 1ku
Control MethodCCM
Device TypeSingle-phase PFC
Operating Supply Current(mA)4
Operating Supply(Max)(V)17
Peak Output Sink Current Gate Drive(A)1.2
Peak Output Source Current Gate Drive(A)-1.2
Practical Operating Frequency(Max)(MHz)0.25
Special FeaturesAverage Current Mode
Enable
OVP
Startup Current(mA)0.15
UVLO Thresholds On/Off(V)10.2/9.7
RoHSНе совместим
  • PFC Family Differences UCC3817A/18A/19A and UCC3817/18/19
    PDF, 32 Кб, Файл опубликован: 18 авг 2003
    The UCC3817A/18A/19A family of PFC controllers (UCC3817A family) is pin for pin compatible with the UCC3817/18/19 family of devices (UCC3817 family). The output stage of UCC3817A family has been updated to allow use of a smaller external gate drive resistor values. For some power supply designs where an adequately high enough gate drive resistor can not be used, the UCC3817A family offers a more r
  • UCC3817 Current Sense Transformer Evaluation
    PDF, 49 Кб, Файл опубликован: 13 фев 2004
  • Synchronizing a PFC Controller from a Down Stream Controller Gate Drive
    PDF, 103 Кб, Файл опубликован: 3 ноя 2000
    Due to pending line harmonic requirements at higher power levels, power factor correction (PFC) is required in some ac-to-dc off-line power converter applications. This type of power converter can be designed with two cascaded power stages similar to the configuration in Figure 1. The first stage is a boost converter that converts the ac voltage to dc voltage with PFC. The output voltage of the bo
  • Startup Current transient of the Leading Edge Triggered PFC Controllers
    PDF, 43 Кб, Файл опубликован: 30 июн 2004
  • Avoiding Audible Noise at Light Loads When Using Leading Edge Triggered PFC Con (Rev. C)
    PDF, 57 Кб, Версия: C, Файл опубликован: 13 апр 2011
    This application note applies to the TI average current mode, leading edge modulation PFC controllers. See Applicable Device Table for part numbers.
  • DN-66 UC3854A/B and UC3855A/B Provide Power Limiting with Sinusoidal Input (Rev. A)
    PDF, 80 Кб, Версия: A, Файл опубликован: 6 ноя 2001
Серия: UCC3819A (4)
  • Semiconductors > Power Management > Offline and Isolated DC/DC Controllers and Converters > Power Factor Correction
На английском языке: Datasheet Texas Instruments UCC3819APW
