Datasheet Texas Instruments UC1863L — Даташит
| Серия | UC1863 |
| Модель | UC1863L |
Резонансные контроллеры источников питания 20-LCCC от -55 до 125
Resonant-Mode Power Supply Controllers datasheet
PDF, 3.9 Мб, Версия: B, Файл опубликован: 13 сен 2007
Купить UC1863L на РадиоЛоцман.Цены — от 3 122 до 4 489 ₽10 предложений от 10 поставщиков Микросхема Контроллер PWM, Voltage Mode PWM Controller 500mA 550kHz 20Pin CLLCC Tube | |||
| UC1863L883B Texas Instruments | 3 122 ₽ | ||
| UC1863L Texas Instruments | 4 489 ₽ | ||
| UC1863L Texas Instruments | по запросу | ||
| UC1863L | по запросу | ||
| Pin | 20 |
| Package Type | FK |
| Industry STD Term | LCCC |
| JEDEC Code | S-CQCC-N |
| Package QTY | 1 |
| Carrier | TUBE |
| Маркировка | UC1863L |
| Width (мм) | 8.89 |
| Length (мм) | 8.89 |
| Thickness (мм) | 1.83 |
| Pitch (мм) | 1.27 |
| Max Height (мм) | 2.03 |
| Mechanical Data | Скачать |
| Control Method | Voltage |
| Duty Cycle(Max) | 50 % |
| Frequency(Max) | 500 kHz |
| Frequency(Min) | 50 kHz |
| Рабочий диапазон температур | от -55 до 125 C |
| Package Group | LCCC |
| Package Size: mm2:W x L | 20LCCC: 79 mm2: 8.89 x 8.89(LCCC) PKG |
| Rating | Military |
| Special Features | Error Amplifier,Soft Start,Soft Switching,Multi-topology |
| Topology | Full-Bridge,Half-Bridge,Push-Pull |
| UVLO Thresholds On/Off | 8/7 В |
| Vin(Max) | 22 В |
| Vin(Min) | 7 В |
| RoHS | See ti.com |
- U-138 Zero Voltage Switching Resonant Power ConversionPDF, 794 Кб, Файл опубликован: 5 сен 1999
This application note explores the technique of zero voltage switching in modern power conversion. It describes several ZVS topologies and applications limitations of the ZVS technique and a generalized design procedure. Two design examples are presented: a 50W DC/DC converter and an off-line 300W multiple output power supply. This discussion concludes with a performance comparison of ZVS conve - U-122 A New Family of Integrated Circuits Controls Resonant Mode PowerPDF, 272 Кб, Файл опубликован: 5 сен 1999
This application note introduces the UC3861-8 family of ICs which are optimized for the control of zero-current-switched and zero-voltage-switched quasi-resonant converters. Differences among members of this device family result from the various combinations of UVLO thresholds and output options. The one-shot pulse steering logic is configured to program either on time for ZCS systems (UC1865-186
Серия: UC1863 (6)
- Semiconductors > Space & High Reliability > Power Management Products > Offline and Isolated DC/DC Controller and Converter
