Datasheet Texas Instruments THS6012IDWPR — Даташит
СерияTHS6012
МодельTHS6012IDWPR
Драйвер двойной дифференциальной линии, 500 мА 20-SO PowerPAD от -40 до 85
500 mA Dual Differential Line Driver datasheet
PDF, 1.1 Мб, Версия: F, Файл опубликован: 28 июн 2012
Pin20
Package TypeDWP
Industry STD TermHSOIC
Package QTY2000
МаркировкаTHS6012I
Width (мм)7.52
Length (мм)12.82
Thickness (мм)2.55
Max Height (мм)2.65
2nd Harmonic80 dBc
3rd Harmonic85 dBc
@ MHz1
Acl, min spec gain1 V/V
Additional FeaturesN/A
АрхитектураCurrent FB
BW @ Acl140 МГц
CMRR(Min)62 дБ
CMRR(Typ)70 дБ
GBW(Typ)140 МГц
Input Bias Current(Max)10000000 pA
Iq per channel(Max)13 мА
Iq per channel(Typ)11.5 мА
Количество каналов2
Offset Drift(Typ)20 uV/C
Output Current(Typ)500 мА
Package GroupSO PowerPAD
Package Size: mm2:W x L20SO PowerPAD: 133 mm2: 10.405 x 12.825(SO PowerPAD) PKG
Rail-to-RailNo
Slew Rate(Typ)1300 V/us
Total Supply Voltage(Max)33 +5V=5, +/-5V=10
Total Supply Voltage(Min)9 +5V=5, +/-5V=10
Vn at 1kHz(Typ)1.8 нВ/rtГц
Vn at Flatband(Typ)1.7 нВ/rtГц
Vos (Offset Voltage @ 25C)(Max)5 мВ
  • Evaluation Modules & Boards: THS6012EVM
    THS6012 High Speed Amplifier Evaluation Modules
  • Active Output Impedance for ADSL Line Drivers
    PDF, 636 Кб, Файл опубликован: 26 ноя 2002
    Signal termination is very common in bidirectional communication systems. Termination allows for receiving signals while transmitting different signals at the same time. With the increasing popularity of asymmetrical digital subscriber lines (ADSL), the requirement for a low power line driver amplifier combined with line termination becomes a very difficult goal. This application note examines the
На английском языке: Datasheet Texas Instruments THS6012IDWPR
