Линейка продуктов KEEN SIDE
Datasheet Texas Instruments UC2834QG3 — Даташит
СерияUC2834
МодельUC2834QG3
Высокоэффективный линейный регулятор 20-PLCC от -40 до 85
High Efficiency Linear Regulator datasheet
PDF, 1.1 Мб, Файл опубликован: 5 сен 1999
Pin20
Package TypeFN
Industry STD TermPLCC
JEDEC CodeS-PQCC-J
Package QTY46
МаркировкаUC2834Q
Width (мм)8.96
Length (мм)8.96
Thickness (мм)4.06
Max Height (мм)4.57
Fixed Output Options1.5 В
Iq(Typ)5.5 мА
Output OptionsFixed Output
Package GroupPLCC
Package Size: mm2:W x L20PLCC: 80 mm2: 8.96 x 8.96(PLCC) PKG
Thermal Resistance ОёJA64 В°C/W
Vin(Max)36 В
Vin(Min)5 В
Vout(Max)35 В
Vout(Min)2 В
  • Versatile UC1834 Optimizes Linear Regulator Efficiency
    PDF, 463 Кб, Файл опубликован: 5 сен 1999
    Linear voltage regulators have long been an important resource to power supply designers. Three-terminal fixed-voltage linear regulators find extensive use as spot regulators and as post-regulation stages fed by switched-mode supplies. However while inexpensive and simple to use these devices have several performance limitations. They are inefficient power converters they lack versatility an
  • Semiconductors > Power Management > Linear Regulator (LDO) > LDO Controller (External FET)
На английском языке: Datasheet Texas Instruments UC2834QG3
