Datasheet Texas Instruments ADS8341EB/2K5G4 — Даташит
Серия | ADS8341 |
Модель | ADS8341EB/2K5G4 |
16-битный 4-канальный аналого-цифровой преобразователь с дискретизацией последовательного вывода 16-SSOP от -40 до 85
ADS8341: 16-Bit, 4-Channel Serial Output Sampling Analog-To-Digital Converter datasheet
PDF, 1.4 Мб, Версия: D, Файл опубликован: 15 апр 2003
Pin | 16 | 16 | 16 |
Package Type | DBQ | DBQ | DBQ |
Industry STD Term | SSOP | SSOP | SSOP |
JEDEC Code | R-PDSO-G | R-PDSO-G | R-PDSO-G |
Package QTY | 2500 | 2500 | 2500 |
Carrier | LARGE T&R | LARGE T&R | LARGE T&R |
Маркировка | B | ADS | 8341E |
Width (мм) | 3.9 | 3.9 | 3.9 |
Length (мм) | 4.9 | 4.9 | 4.9 |
Thickness (мм) | 1.5 | 1.5 | 1.5 |
Pitch (мм) | .64 | .64 | .64 |
Max Height (мм) | 1.75 | 1.75 | 1.75 |
# Input Channels | 4 |
Analog Voltage AVDD(Max) | 5.25 В |
Analog Voltage AVDD(Min) | 2.7 В |
Архитектура | SAR |
Digital Supply(Max) | 5.25 В |
Digital Supply(Min) | 2.7 В |
INL(Max) | 6 +/-LSB |
Input Range(Max) | 5.25 В |
Тип входа | Pseudo-Differential,Single-Ended |
Integrated Features | N/A |
Interface | Serial |
Multi-Channel Configuration | Multiplexed |
Package Group | SSOP |
Package Size: mm2:W x L | 16SSOP: 19 mm2: 3.9 x 4.9(SSOP) PKG |
Power Consumption(Typ) | 3.2 mW |
Rating | Catalog |
Reference Mode | Ext |
Разрешение | 16 Bits |
SINAD | N/A дБ |
SNR | 86 дБ |
Sample Rate (max) | 100kSPS SPS |
Sample Rate(Max) | 0.1 MSPS |
THD(Typ) | -90 дБ |
- Determining Minimum Acquisition Times for SAR ADCs, part 1 (Rev. A)PDF, 227 Кб, Версия: A, Файл опубликован: 10 ноя 2010
This application report analyzes a simple method for calculating minimum acquisition times for successive-approximation register analog-to-digital converters (SAR ADCs). The input structure of the ADC is examined along with the driving circuit. The voltage on the sampling capacitor is then determined for the case when a step function is applied to the input of the driving circuit. Three different - Determining Minimum Acquisition Times for SAR ADCs, part 2PDF, 215 Кб, Файл опубликован: 17 мар 2011
Серия: ADS8341 (8)
- ADS8341E ADS8341E/2K5 ADS8341E/2K5G4 ADS8341EB ADS8341EB/2K5 ADS8341EB/2K5G4 ADS8341EBG4 ADS8341EG4
