Линейка продуктов KEEN SIDE
Datasheet Texas Instruments TPA3112D1PWPR — Даташит
СерияTPA3112D1
МодельTPA3112D1PWPR
Моно-усилитель звука класса D, 25 Вт, без фильтров и спикергуардом (TPA3112) 28-HTSSOP от -40 до 85
TPA3112D1 25-W Filter-Free Mono Class-D Audio Power Amplifier With SpeakerGuardв„ў datasheet
PDF, 1.4 Мб, Версия: D, Файл опубликован: 7 дек 2016
Pin28
Package TypePWP
Industry STD TermHTSSOP
Package QTY2000
МаркировкаTPA3112D1
Width (мм)4.4
Length (мм)9.7
Thickness (мм)1
Max Height (мм)1.2
Analog Supply (V)26 Min
Audio Input TypeAnalog
Closed/Open LoopClosed
Control InterfaceHardware
Package GroupHTSSOP
Package Size: mm2:W x L28HTSSOP: 62 mm2: 6.4 x 9.7(HTSSOP) PKG
Power Stage Supply(Max)26 В
Power Stage Supply(Min)8 В
Power to Bridge Tied Load(Max)25 W
Speaker Channels1 Max
Supported Bridge Tied Load(Min)4 Ohms
  • Evaluation Modules & Boards: TPA3112D1EVM
    TPA3112D1 Evaluation Module
  • AN-1737 Managing EMI in Class D Audio Applications (Rev. A)
    PDF, 140 Кб, Версия: A, Файл опубликован: 1 май 2013
    Electromagnetic interference (EMI) is an unwanted disturbance caused in an electrical circuit byelectromagnetic radiation emitted from an external source. The disturbance may interrupt, obstruct, orotherwise degrade the effective performance of the circuit.
  • Using Thermal Calculation Tools for Analog Components
    PDF, 1.1 Мб, Файл опубликован: 2 сен 2010
    This document provides general guidance on the use of toolsand calculations for thermal estimates of component operating temperatures for analog devices. Of particularfocus are components with direct thermal paths to the PCB which is common for components which need a low thermal resistance to manage the dissipated power. This document provides practical considerations for estimation of o
  • AN-1849 An Audio Amplifier Power Supply Design (Rev. B)
    PDF, 1.9 Мб, Версия: B, Файл опубликован: 1 май 2013
    This application report provides design information for a power supply for use with our newest offering of high-performance, ultra high-fidelity audio amplifier input stage ICs.
  • Guidelines for Measuring Audio Power Amplifier Performance
    PDF, 765 Кб, Файл опубликован: 30 окт 2001
    This application note provides guidelines for measuring the date sheet parameters of Texas Instruments audio power amplifiers (APAs) using prefabricated evaluation modules (EVMs). The primary equipment used for the measurements consists of the System Two audio measurement system by Audio Precision , a digital multimeter (DMM), and a dc power supply.
Серия: TPA3112D1 (2)
  • Semiconductors > Audio > Mid-Power Audio Amplifiers (10-50W) > Analog Input Amplifiers
На английском языке: Datasheet Texas Instruments TPA3112D1PWPR
